plasma boost gauge :)
Old Dec 15, 2010 | 03:03 PM
sabreuk's Avatar
well fitted a plasma boost gauge today and cant be more impressed with it, its in psi instead of bar but as the 2.4 2lte only kicks out 11psi before limp mode i thought this was the way forward. ill get some pics of it fitted to the truck but here is the gauge on ebay the item number for it 180521851776
ive also orderd a cool plasma dial kit which should be here tomoz heres the item number if intrested 250732280288 ill also post pics of it once fitted. if any one needs any help on fitting either giz a shout or if ya want a step by step guide for the dials let me know and ill show ya how to do it.
Old Dec 15, 2010 | 10:10 PM
peow130's Avatar
pics or it didnt happen.
Old Dec 15, 2010 | 11:10 PM
sabreuk's Avatar
I didn't get chance to get any pics lastnight mate was around 2300 once I finished messing about. I'll get pics of the gauge and a short video so you can see it working aswell. Like I said I'm waiting for the post to deliver the new clicks should also be here today.
Old Dec 16, 2010 | 01:11 AM
sabreuk's Avatar
Originally Posted by razed
fuel cut is not caused by boost. the ecu doesn't measure boost.
it is caused by air flow meter reading and injector duration, which are inderictly influenced by boost. if the afm is reading near fully open and injectors are held open too long the ecu turns off the injectors.
you can change that by changing the afm calibration and useing higher-flow injectors to compensate... might need a higher flow fuel pump to work that though at higher air flow / boost conditions.
want to see the meter though.
hiya mate, mine is a 2.4td and the gauge is mesuring the vacuum line coming off the high pressure turbo switch so it is reading accuratly to the vacuum pressure going to the turbo, on the 2.4 a common mod to up boost pressure is to put washers behind the actuator but after 11.psi of boost pressure it puts the ecu in to limp home mode for over boosting. so if any one has a 2.4 or 3.0 td dont put a boost controller on as they are a waste of time and the gain you would get isnt worth the hassle.
anyway here is a pic of the gauge in the truck and a short vid of it running
http://www.youtube.com/watch?v=p4wJF2zgE0U
Attached Thumbnails plasma boost gauge :)-gauge-small.jpg
Old Dec 16, 2010 | 01:15 AM
sabreuk's Avatar
did have a look at the vid razed?
Old Dec 16, 2010 | 07:33 AM
sabreuk's Avatar
well at last the new plasma dials turned up and im bout to go fit them ill post the pics after i have fitted them but the kit looks good with very precise fitting for the hilux instead of those nasty universal fitting guides you get.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
dbollier123
Sep 29, 2015 05:23 PM
