When to replace fuel pump 94 4Runner 3VZE
Old Dec 19, 2010 | 10:04 PM
arielb1's Avatar
Thank you.
I searched but no luck
When should I replace my fuel pump? I have 124K miles.
1stToyotaparts.com sells for $230
Autohausaz.com sells
Denso with filter $179
Kyosan with filter $193
What did you do? Thank you
Old Dec 19, 2010 | 10:26 PM
marko3xl3's Avatar
Unless you're having engine stumbling/dying issues or if the fuel pump is whining, there's no reason to replace it. They're pretty solid on the 4Runners.
You could always hook up a fuel pressure gauge and see how well it's performing just to the sure though.
Old Dec 19, 2010 | 10:34 PM
James Woods's Avatar
Fuel filter is a maintenance item, not the fuel pump. No need to replace it unless there is a problem or a need for more fuel due to performance.
Old Dec 20, 2010 | 08:27 AM
RobD's Avatar
I have over 456 000 kms (~285,000 miles) on mine with no issues.
Old Dec 20, 2010 | 08:47 AM
Elton's Avatar
thing that kills fuel pumps fast is running it low on gas alot
Old Dec 20, 2010 | 08:57 AM
arielb1's Avatar
Thank you for your opinions
I will just change out the filter. Nice to know these are solid.
I plan to purchase the filter at autohausaz.com or 1sttoyotaparts.com
Many thanks.
Old Dec 20, 2010 | 09:09 AM
drmix's Avatar
I also heard that if you dont replace the fuel filter often enough it will kill your fuel pump. Due to the fuel pump has to work harder to compensate for the low flowing filter
Old Dec 20, 2010 | 09:14 AM
^ yes it does, I just replaced a fuel pump on a Silverado and when I dumped the old fuel out of the fuel filter, it came out brown.
Old Dec 20, 2010 | 01:42 PM
Elton's Avatar
when i get to 200k here soon im replacing the filter
Old Dec 20, 2010 | 03:05 PM
camo31_10.50's Avatar
Fuel Filter here i come!
puffin04
Jul 10, 2015 09:17 PM
rbravo1
Jun 29, 2015 01:34 PM
kazuya2416
Jun 27, 2015 12:24 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dennis140
Jun 17, 2015 10:37 AM
