89 pickup 3.0 missfiring
Old Dec 13, 2010 | 07:13 PM
jhouston420's Avatar
I got an 89 3.0 v6 and the bearing in the distributor just went bad and was making a real bad noise and running off 1 mabey 2 cylinders. I replaced the distributor along with rotor, cap, wires, and plugs and it helped a lot but its still missing. Ive checked the wires and there in correct spots. The check engine light does come on after about 5 minutes of driving but i havn't pulled any codes yet. If any has any ideas/suggestions let me know, thanks.
Old Dec 13, 2010 | 10:30 PM
pbiker11's Avatar
Pull the codes and postup or just search em and see what they read. Thatll tell you a lot alone.
Old Dec 13, 2010 | 11:38 PM
sam333's Avatar
You didnt say if you adjusted/ checked your timing.
How was it running before the bad dist?
Are you getting a code 25? All that missing will cause your o2 sensor to read a lean air fuel mixture.
Charecter1
Nov 6, 2023 10:08 AM
XtraCab
Apr 12, 2020 05:25 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
Roger Borba II
Jul 9, 2015 05:05 PM
