front stub shaft removal with a locker in there
Old 02-27-2010, 09:52 AM
Junkers88's Avatar
I'm trying to get the stub shaft off of my front IFS since the axle seal is leaking. I read somewhere that there is supposed to be a C clip holding the axle in there but for the life of me I can seem to see it because of the lockrite that's in there.
Do I have to pull the locker to get the stub shaft out? Please tell me no.
Old 02-27-2010, 10:06 AM
RMA
RMA's Avatar
check this page out.
http://www.gearinstalls.com/ifs.htm
from zuks site .
just use a large screwdriver.
Old 02-27-2010, 10:19 AM
Junkers88's Avatar
from zuks site .
That looks like it would work but I can't get a screwdriver in there. The Lockrite is in the way. I'll go back out and try that. I thought you had to remove the clip before it would come out.
Thanks!
Old 02-27-2010, 10:38 AM
Junkers88's Avatar
Got it! Now I'm glad I did since I now know that there isn't an axle seal in there and the freaking third member has sand all in it....
Thanks again.
Old 02-27-2010, 12:10 PM
InternetRoadkill's Avatar
FYI, you can often get those shafts out by using a block of wood and a BFH. Angle a length of 2x4 against the back side of the flange and smack it as best you can to unseat the spring clip holding the shaft in.
Old 02-27-2010, 09:09 PM
OutlawMike's Avatar
When I did my lockright I used the BFH technique, along with a big pry bar. Loads of fun.
You can get the axle seals at the dealer, I replaced both of mine when I had it apart.
Old 02-27-2010, 09:59 PM
Junkers88's Avatar
I did something similar. I used a dead fall hammer and after two hits it pulled out. So easy.
oldirtydirt
02-23-2020 09:30 AM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
88sasturbotoy
08-11-2015 01:56 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: front stub shaft removal with a locker in there
