After locker install and wheeling I have a new vibration
Alright folks, I'm going to need some help with this one.
I recently dropped in a front locker for the rig and have been slowly learning what a double locked rig can and cannot do. (89 4runner, 22re, 5 speed, Aussie in the rear, Lockrite in the front, 4.56's and 31's but most of ya'll knew that from my posts over the last year).
Went wheeling the day I put the locker in and things were freaking awesome. I did notice a slight vibration on the way home that only happens when I'm holding the throttle to maintain speed. Example: I'm doing 70 on the highway and holding at 70 it will vibrate enough to "feel" it in the truck. If I accelerate or let off the pedal it goes away.
That wheeling trip was almost 90% mud with a few minor rock crawls, as I said I'm trying to learn the rigs capabilities with the front locked, and I did my best to wash all the mud off of the drive train when I was done.
So far I have no strange steering issues, no wheel hop or tracking issues, fluid levels in the motor/tranny/tcase/diffs are where they should be. Now if I'm on the street and can feel the vibration I can clutch the rig or just pull it out of gear and the vibration is gone.
I'm hoping this is something as simple as a loose nut (not the one in the drivers seat thank you) or something similar.
Help?
edit: Having two lockers makes this thing a blast to wheel.... I mean that.
Help?
Didyou mark the drive shaft before you pulled it off so its on the same as before the install, just thought i would ask. I had to turn mine till I found where it vibrated the least.
Oh and SHUSH!.
I have not yet although I can't see them going out after one wheeling trip unless the front being locked would have caused some strain on the rear.
Wheel weights? Would a loss of one or two cause this??
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
rushw
07-18-2015 01:46 PM
