22RE Deckplate Mod
Old Mar 4, 2010 | 10:47 PM
fender250's Avatar
22RE Deckplate Mod
I did a search and found little info on this. Plenty of info on the bigger yota engines, but not the 22re. Has anyone around here done this to their 4 banger? If so, was it worth it? What size of deck plate did you use?
Old Mar 4, 2010 | 11:12 PM
Elton's Avatar
just remove the headlight tube
Old Mar 4, 2010 | 11:17 PM
toyota4x4907's Avatar
One of the previous owners of my 4runner removed the intake tubing behind the headlight and that little tube thats at the bottom of the airbox. I wouldnt say it increases power, but it makes it sound awesome.
Old Mar 5, 2010 | 04:37 AM
fender250's Avatar
I'd like to have the option of plugging the hole that the deckplate mod provides for mudding/offroading.
Old Mar 5, 2010 | 06:49 AM
lilbroyota's Avatar
did that to mine awhile back i mean have you seen the little tiny holes there supposed to breath through? and to fender250 i mud all the time heck i have to coming out of my driveway too but it hasn't botherd it yet Lilbroyota
Old Mar 30, 2010 | 11:51 PM
Dgfriend707's Avatar
Have you personally done it?
And if so can you tell much of a difference?
Old Mar 31, 2010 | 12:09 AM
Elton's Avatar
i have not
Old Mar 31, 2010 | 12:28 PM
Wellp, im gonna go try it lol and ill tell you what happens shortly.
Old Mar 31, 2010 | 01:41 PM
Took me 5 minutes...
Results are: Cant really tell a power gain, But definately made a deep awesome sound...
Im putting a screen in front of the hole.VVV.Because I seem to get a lot of leaves in my airbox...lol
What was in front of the original intake tube...
Again...
I've only driven it around the block...So maybe I will feel a HP gain, maybe not... Who cares? It sounds awesome either way!
Old Mar 31, 2010 | 01:47 PM
MaK92-4RnR's Avatar
I've done it on my 3vze. it doesn't do anything except add a faint air induction noise. if you want a gain, do a FIPK K&N kit and intake battery swap.
Old Jun 21, 2012 | 08:20 PM
Gregs94Toy's Avatar
I did this tonight {minus actual deck plate, but with hole like pic above}...it has a strange low pitched rattle at low rpm or idle, almost like something is loose or vibrating...is that just the air pressure as it hits a certain pitch making that rumble?
Old Jun 21, 2012 | 09:14 PM
BigBluePile's Avatar
Theres not ONE thing you can do to a 22re to make an improvement. It's a lot of things combined that will really make a noticable difference.
Old Jun 22, 2012 | 06:27 PM
combatcarl's Avatar
Y'know I've got a boring weekend coming, I may just do this for fun and a lack of better things to do. Do ya think you could pipe in a snorkel to that? Not looking at mine right now, but I might size it up when I'm in there... And I wonder if this'll change my PAIR honk on decel...
Old Jun 22, 2012 | 08:02 PM
Dirt Driver's Avatar
And here I always thought a deck plate was for bolting onto an engine block before it gets bored and honed...
Old Jun 22, 2012 | 11:18 PM
abecedarian's Avatar
That's what a deck plate is.
Old Jun 23, 2012 | 01:29 AM
combatcarl's Avatar
Isn't it a "marine deck plate" that's used? (In some cases) But yeah, I thought it sounded like a term I'd heard related to something else...
Old Jun 24, 2012 | 07:18 PM
In automotive parlance the "deck" is the top of the engine block, and "deck height" is a somewhat complicated measurement related to the piston, rods and crank, bushing and bearing offsets and the engine block, though is generally the measure from the centerline of the crankshaft to the top of the engine block.
A deck plate is a physical "guide" used to center boring and honing tools along the centerline of the cylinder bores. It's use is indespensable for blueprinting an engine, and just as valuable when performing over-boring and honing on such a modified engine.
Loosely speaking, a deck plate mod could be anything that changes the horizontal aspects of something.
Changing vertical aspects would be bulkhead modifications.
Old Jun 25, 2012 | 12:01 PM
And it allows the cylinders to be bored with distortion and stresses applied similar to when the engine is assembled. I have *heard* that max-effort race teams may even go so far as to circulate coolant through them heated to operating temperature.
http://www.mustangandfords.com/techa.../photo_19.html
Old Jun 25, 2012 | 01:33 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Abe....Dirty Dude......let the newbies have their fun. They'll learn.....in time.
Old Jun 25, 2012 | 02:43 PM
combatcarl's Avatar
Hey now. Not everybody needs a couple thousand posts to know anything. Sometimes, its better to get Abe to explain it right the first time, see? If ya can't contribute...well, ya know.
