HELP temperature sensor bad?
Old Feb 28, 2010 | 06:11 PM
Blk63vette's Avatar
Hello I need some opinions..
My temperature gauge (stock one to the left) needle is not working right now. I dont think its the gauge itself. I think its the sensor. I have a 22RE engine 1994 Toyota 2WD truck. I think the sensor is green in color (top) up at the front of engine. Does it need any pipe tread tape to seal it? Does it need a special socket to take it out? How much does a sensor cost?
Thanks
Pete
Old Feb 28, 2010 | 08:16 PM
myyota's Avatar
Last time i replaced a temp sensor it was under 15.00. If i remember right the temperature sending unit is located on the intake manifold in the middle next to the valve cover. The one your refering to at the front of the engine is the temperature sensor used by the computer.
Old Feb 28, 2010 | 09:02 PM
laskt9's Avatar
if its the gauge thats not working its not the one on the front of the engine... its on the top of the engine with a single wire going to it
Old Feb 28, 2010 | 09:06 PM
Mountain Cop's Avatar
Mine wasn't working either. Turned out to be the contact. Try the cheap fix first!
Old Mar 1, 2010 | 08:21 AM
Blk63vette's Avatar
Hello
I will try and clean the contact points first..I will look for it on the intake manifols in the middle with one wire..
Thanks
Pete
P.S. Does anyone have a picture of it?
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
nonstop
Jul 24, 2015 06:29 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
