Long travel front, rear?
Old Mar 7, 2010 | 11:35 AM
90runnerfan's Avatar
so ive thought long and hard and long travel is for me, so i ordered my king shocks the other day, and savin some dough for TC kit but im contemplating on what to do in the rear. i know leafs is cheaper easier and work good but would a 3 link be a way to go? i see advantages in both and from what i read a 4 link on my 4runner i would have to chop up way to much of the bed. just lookin to get some input. thanks guys. 90 4runner 3.0 auto 4x4
Old Mar 7, 2010 | 05:10 PM
peow130's Avatar
4 link with coilovers would be better imo.
The 3 link makes the axle move left and right slightly, and with a 4 link you can run long travel coilovers.
You could do spring under axle leaf springs, and it would have some pretty good droop.
Old Mar 8, 2010 | 03:06 AM
abecedarian's Avatar
Leaf spring under axle? That's the 2wd truck setup.
Leaf over axle (i.e. stock 1st gen, all 4wd trucks) would droop just as well, and have about 3-4" more lift.
But it's a 90 with coils we're talking about.
So, 90runnerfan- the TC LT kit will push your front wheels wide, about 3" wider over stock on each side. You might consider a T100 rear axle to keep the rear track width similar to the front. Sorry I can't help you much beyond that though.
Old Mar 8, 2010 | 07:30 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I'd rather buy another 4WD, than buy that TC kit...
EDIT: You still have the same front diff and shafts, only longer...
So why pay for that? With a SA kit (and you'll need a coil front, not leaf) you get a super common 8" diff, one set of joints, and all the aftermarket you can hope for.
So for the same coin, you get stronger axles as well...? Whoa, man... heavy...
Old Mar 8, 2010 | 10:55 AM
wreckedrex's Avatar
How well does a SA setup work for higher speed stuff though? Seems like long travel IFS setups are more popular among the desert racing crowd.
I'd like to see what folks are doing for the rear axle too, I've been kicking the long travel idea around also.
Old Mar 8, 2010 | 11:23 AM
Why not specify those are your intentions in your thread then?
if you don't need desert racing, then I suggest you make a baby Fj80 out of it...
Old Mar 8, 2010 | 11:48 AM
yea, kinda still no sure but leanin towards leafs, i perfer high speed stuff than rock crawlin, besides big bear you can do in IFS no problem you dont need solid axle for everything but they both look cool all flexed out.
Old Mar 8, 2010 | 04:45 PM
wreckedrex's Avatar
OP didn't mention hardcore crawling or anything else that would suggest he need a SAS either I assumed the choice to mod the ifs setup was made for a reason.
Old Mar 8, 2010 | 05:20 PM
akaphilly's Avatar
heres a pretty cool truck. hes running a long shackle above framerail. i think deaver springs
the full build. prepared to be wowed.
http://www.pirate4x4.com/forum/showthread.php?t=859418
Old Mar 8, 2010 | 07:22 PM
tc's Avatar
tc
Your 4link will do fine, especially if you build some longer links with flexier joints ... or you can go whole hog like I did
https://www.yotatech.com/forums/f116...thread-153382/
There really isn't any reason/need to go to coilovers. Separate springs/shocks work just as well, and package in a much shorter height.
If you want to do leafs, understand that they are not quite as easy as the internet would lead you to believe. Here's a long travel setup I did for a friend:
http://www.ttora.com/forum/showthread.php?t=138937
Start reading up on the desert section of TTORA and race-dezert.com. In particular, look for a 3rd gen buildup by "Chaplain". Building these trucks is a lot more exacting than building a pure rock crawler, but you are rewarded with the best all-around setup IMHO.
Old Mar 8, 2010 | 07:55 PM
peow130's Avatar
@Abe, somebody on here mentioned that with the leafs under the axle, then there is more droop.
Old Mar 9, 2010 | 05:17 AM
Robert m's Avatar
that was probably me
quoted from dezertrangers
Originally Posted by matt_helton
the bennefits to a SUA are as follows.......
more total wheel travel and more up travel from ride height while still allowing for a super low ride height. axle wrap/wheel hop is also greatly reduced with an SUA set up.
Old Mar 9, 2010 | 06:22 AM
tc's Avatar
tc
I don't buy the "more travel" bit ... definitely lower ride height.
Old Mar 9, 2010 | 11:14 AM
5point0toyota's Avatar
who sells thos fenders?
Old Mar 9, 2010 | 11:29 AM
on which truck? ^
Old Mar 9, 2010 | 01:18 PM
akaphilly's post the one on the lift i have seen a few trucks with that baja front fender where are they getting them?
Old Mar 9, 2010 | 01:47 PM
akaphilly's Avatar
poly performance
Old Mar 9, 2010 | 07:39 PM
tc's Avatar
tc
Google fiberglass fender toyota ...
Toyota fiberglass, Hanneman, there's several manufacturers of them
Old Mar 9, 2010 | 07:50 PM
yea i got hanneman on my runner bought them used, they have some small small small cracks for 50 bucks love em just need to change out the rear coils for now to make it look a bit better.
Old May 12, 2011 | 11:00 AM
Leonardo Muniz's Avatar
nice build
