93 truck electrical issue
Old Mar 6, 2010 | 09:50 AM
Toyota Novice's Avatar
Having an issue with electrical-- First thing was battery/e-brake lights came on in dash while driving whenever I would hit the fan on or turned on the headlghts, then when I turned off the truck battery didn't have enough juice to start it back up. Parts store said battery and alternator are good, so I'm looking for next steps. My dad-in-law says starter, my buddy says voltage regulator, so I'm gonna look into those... any other ideas?
Old Mar 6, 2010 | 10:06 AM
CappyKD's Avatar
Check your grounds. Usually those lights together mean bad alternator.
Could also be this.
https://www.yotatech.com/forums/f116...26/index2.html
Old Mar 6, 2010 | 11:10 AM
Ok, so I read through the thread you mentioned-- to be clear (tell me if I misunderstood here) , they're talking about replacing/upgrading the wiring between the + battery terminal and fuse box, and possibly also the cable between the battery and alternator.
As far as checking the grounds, should I just be checking visually & cleaning or are you suggesting I put some sort of meter on them? My buddy told me I can get to the Toyota factory manuals through this site that show all the wiring diagrams-- is that true? (I can't find it!)
P.S.- Obviously I'm new at all this, so try to use "dumb speak" as much as possible, thanks!
noahstancik
Jul 10, 2015 11:18 AM
bigblue82
10
Jul 6, 2015 08:27 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
Dylan199119
Jun 25, 2015 09:54 PM
Taz22R
Jun 21, 2015 04:44 PM
