Clutch problems!!!!!!
Old Feb 23, 2010 | 07:29 PM
91Toyota's Avatar
Recently randomly I can't get my truck into gear. I push the clutch in and nothing happens. When I get it almost into gear it starts to move a little. After a little bit the clutch is normal again.
Today, I start it in gear and my truck rolls into a curb. It moved slowly because the clutch was slipping. I couldn't get it back into gear though.
So, I have about 35k miles on this clutch. I treat it very badly. I pop the clutch often.
What could be wrong?
Old Feb 23, 2010 | 07:50 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
slave cylinder... or master...
can you pump it a few times and it work like normal?
Old Feb 24, 2010 | 08:38 AM
91Toyota's Avatar
Yep! I tried bleeding it a couple weeks ago and it didnt make a difference. It happens so randomly. The master and slave are so cheap I might as well just replace them.
Old Feb 24, 2010 | 09:10 AM
I would HIGHLY recommend OEM...
Old Feb 24, 2010 | 06:18 PM
RobD's Avatar
Just as a thought, check for a broken clutch bracket. You'll need to look up under the dash with a flashlight and see if you can find a crack along the side of where the clutch pedal uprights meet the backing plate.
Old Feb 24, 2010 | 06:22 PM
That would probably be accompanied by a squeaking or grinding with using the pedal, and the pedal itself would be loose...
Providing there's enough play to hinder clutch movement...
Old Feb 24, 2010 | 06:51 PM
peow130's Avatar
Maybe your clutch is just burned up...
You say you abuse it by popping the clutch and whatnot, maybe there just isnt any material left on the clutch at all.
Old Feb 24, 2010 | 07:14 PM
Then he'd prolly hear the rivets scraping the flywheel...
Old Feb 24, 2010 | 09:17 PM
91Toyota's Avatar
The clutch is fine. I can spin the tires all day long if I wanted too. And, the clutch wouldn't randomly wear out then work just fine shifting into gears.
The clutch bracket is fine...no cracks and not broken.
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
the1998sr5
Jul 16, 2015 06:20 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
