Powersteering question
Old Feb 25, 2010 | 04:43 PM
tannerc's Avatar
90 4 runnner, ifs
my powersteering works but loses fluid, no evident leaks.
I have found that the 2 vaccume hoses on the bottom of the pump are sucking up the fluid and spitting it into the upperintake.
Is there an easy way to fix this?
Or do I need a new pump?
Thanks,
Old Feb 25, 2010 | 06:26 PM
peow130's Avatar
Did you put power steering fluid in the pump, or automatic transmission fluid?
The toyota Power steering pump uses ATF, not PS fluid
Old Feb 25, 2010 | 06:39 PM
tannerc's Avatar
I put ATF in..
When I pulled the 2 vaccume lines there was fluid in the lines
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
