Help please.....odd knocking in top of motor
Old Jun 19, 2013 | 08:29 AM
rookie6319's Avatar
I have a 1994 Yoda 22re and I have a very odd knocking noise coming from the top of the motor I first thought it was just valves but the more i listen its not the valves...here is what its doing
idles and drives great plenty of power at high RPMs right as i need to shift gears it knocks as i let off the gas and as i am driving as i reach higher RPMs it will knock or when i let off the gas to go down a hill or incline but it never looses power I had a mechanic near by who only works on honda toyota listen to it and he said he has never heard this knock in a 22RE
If anyone can help or if you have an idea as to what it may be please leave a post
Thanks
Old Jun 19, 2013 | 11:15 AM
Bingle's Avatar
Could be a few different things. Run it and get it up to temp so you can do a valve adjust (if it needs it, doesn't hurt to check) and while the valve cover is off check your timing chain guides/tensioner. Make everything looks okay. if that all looks good/checks, do a compression check and look at the color and amount of the deposits on the spark plugs and report back. These are decent diagnostic tools to see if something isn't right (other than mystery "knocking").
Good luck
Old Jun 19, 2013 | 01:56 PM
cman1's Avatar
i would go toward broken timing chain guide.
Old Jun 20, 2013 | 01:38 PM
rookie6319's Avatar
I have tried to adjust the valves and also the oil pump water pump timing cover and head are all new the noise is coming from the back of the motor somewhere....just to stand and listen it sounds like the top of the motor is where the noise is however if you stick a screw driver on the head or valve cover you hear nothing................I have not check the compression or the spark plugs yet just wanted to update the new parts and valve adjustment
Thanks
Old Jun 20, 2013 | 03:11 PM
wyoming9's Avatar
Red face
If you tightened the nuts holding the valve cover to tight it will make a tapping noise
If you have your hand on the valve cover you will feel it
If it is not this .
Is it a knock or more of a rattle from the exhaust from something loose when the exhaust manifold was removed when the head was changed.
I bet it is one of these things.
Old Jun 20, 2013 | 05:26 PM
cman1's Avatar
[QUOTE=wyoming9;52088631]If you tightened the nuts holding the valve cover to tight it will make a tapping noise
wyoming9 you beat me to it,i cant tell you how many times ive seen this!!!!
Old Jun 21, 2013 | 04:26 PM
rookie6319's Avatar
it is a knocking noise....i watched a video on youtube and they was saying rod bearing and this is the same sound mine is making so just to be on the safe side i am replacing all the bearings however i cant find the torque specs for this so i am at a stand still I will update after i get this completed Here is the video that i watched that has the same exact noise as mine
Old Jun 22, 2013 | 06:15 PM
Nogarage's Avatar
Dear Rookie, your rod knock won't go away if you place a screw driver on the valve cover. If you hold the head or valve cover and the knock is silent, then it's not your bearings.
Old Jun 23, 2013 | 05:10 AM
yodafan93's Avatar
if youre not getting metal flakes in your oil, its probably not a bearing, and if you dont have bearings machined to your crank, alot of times theyre just bandaids/ time bombs. its not a permanent fix. doing what everyone else said is easier anyway. check the valve cover, timing chain guides, and be sure you dont have an exhaust leak.
Old Jun 23, 2013 | 05:53 AM
rookie6319's Avatar
just an update for everyone...it was the rod bearings...and the odd thing about it was that i had no metal shavings in the oil pan at all......thanks to all for your input and advice
Old Jun 24, 2013 | 06:48 PM
yodafan93's Avatar
howd you diagnose that? not saying youre wrong. id honestly like to know.
bigjstang
Jun 2, 2025 03:56 PM
cars-guy
Aug 16, 2020 06:59 AM
keithporter83
Jul 18, 2015 12:37 PM
msane99
Jul 17, 2015 10:13 AM
cars-guy
Jul 11, 2015 07:51 PM
