headlight assembly
Old Jun 5, 2013 | 07:49 PM
nacy369's Avatar
headlight assembly
pretty sure I am missing some stuff for my header panel. headlights are currently zip tied into place. Can some one tell me what I all need for my headlights? like housings bezels adjustment screws and what not and where to get order it. Ill try to snap a picture later.
Old Jun 5, 2013 | 08:30 PM
Scrussanation's Avatar
i had that problem as well. JC whitney along with carid.com, autoanything.com, and streetsideauto.com had lots of what I needed... mines an 89 and this is some for those at jcwhitney. love the internet
http://www.jcwhitney.com/replacement...2183y1989g24j1
Old Jun 5, 2013 | 08:32 PM
i even replaced my front plastic grille.. i believe jc whitney too... meant to tell ya its usually not in the lighting section but in the body and trim section... or exterior
Old Jun 6, 2013 | 03:42 AM
nacy369's Avatar
its impossible to find a complete headlight assembly. I really need to find the adjustment screws.
Old Jun 6, 2013 | 03:54 AM
did you not check those?? i bought one for mine so why are you not finding it??
Old Jun 6, 2013 | 04:03 AM
I'm assuming not... I'll make this so easy for you its insane....
http://www.jcwhitney.com/dorman-univ...83y1989g24u0j1
now you can jump around and say especially when
Old Jun 6, 2013 | 07:53 AM
nacy369's Avatar
Ill just take some pics on friday so anyone can pipe in and tell me what I need. Its a salvage title so she needs alot of work.
Old Jun 6, 2013 | 08:02 AM
is what I provided not what you need? it has all the houseings and even the screws....
Old Jun 6, 2013 | 08:21 AM
nacy369's Avatar
It just showed up with retaining clips?
Old Jun 6, 2013 | 08:29 AM
if you look below the clips you will see a selection of headlight retaining rings.. those come with the 4 screws that hold in the sealed bulb. thats what u needed right?? u cant just get the screw alone and most likely the old retaining rings are gonna be bent out of shape on yours anyways correct me if im wrong
Old Jul 27, 2021 | 08:25 AM
jazz1's Avatar
5 Year Member
Old thread but what size are the screws holding headlight retaining ring? Searched but can't come up with a metric size,,,only seeing 8 32 1/2"
Old Aug 4, 2021 | 07:56 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
thread size
You should've started a new thread. This probably wasn't seen.
But here is a thread with your answers and more.
https://www.yotatech.com/forums/f116...ersion-313818/
Feb 15, 2024 05:44 PM
YotaBruce
Aug 12, 2013 08:17 AM
Jason B
9
Sep 26, 2006 05:34 AM
Deathmage
16
Feb 8, 2006 10:32 AM
