check engine light after batt intake swap
I Finally swapped the battery and intake last night and changed to a cone filter. After I was done I started it up and the beast shut down about 20 seconds later, rechecked everything and tried again. This time I took it for a test drive and my results are check engine light, creeping, sputtering, and sounds like a slight backfire out of the afm.
The only thing I can think of since its so close to the intake now that i need to move the internals of the afm a tooth. But in all the write up about this swap it says nothing about a check engine light or havingto mess with the afm internals.
1.yes
2.I'm pretty sure theres only one way
3.yes the 7 wires for the afm
4.never touched any
5.no
6.yesterday before doing this swap the truck was running perfect excep for minor coolant leak
all right, 2 things:
1) re-trace your splices, and make sure all the wires are correct. i've messed wiring up before, and it brings teh suck
2) do you have a check-engine light right now? if so, do this (p 170-172):
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
using a paper-clip or short wire to short terminals 'TE1' and 'E1'
yeah, it's not too bad if you have all the stuff beforehand
But why would that code show up after the swap. It seems like its not getting enough air, and i think the sub o2 is for like california emmisions
side note- I noticed the little boost in power almost instantaneous.
