since the toy is down what else
Old Nov 10, 2013 | 11:49 AM
whippedandchained's Avatar
Well the rear gear is out. So I decided to tear into the engine to see if I can find out why its running rich and seems to have a miss. Mind you this truck does have 265000 miles and I know the PO never did maintenance So first, pull plug wires and yeah all are firing as should be, but still seems like a miss. So I decide to check compression, all are at 105 except cyl 6 its at 80 all hold the pressure no leaks. Checked timimg spot on since i just did the belt less then 1500 miles. So since I need to replace the valve cover gaskets why not check the valves. My question is what are the specs and what else should I check while I have it this far apart?
Old Nov 10, 2013 | 11:53 AM
Sorry its a91 3.0 well checked all the valves to can and all are between .007 and .010. Dumb arse moment of the day wife comes out and tells me keep it simple stupid so I check the codes and get 25 and 41. Well good thing is valves check out and no more leaky valve covers so on to the next
Old Nov 10, 2013 | 02:55 PM
4runrjunkie's Avatar
That may be your issue. The service manual specs 142psi minimum, and more importantly a maximum of 14psi difference between cylinders. With one cylinder running low on compression that might be what your feeling as a miss.
http://personal.utulsa.edu/~nathan-b...66compress.pdf
Old Nov 12, 2013 | 04:46 PM
Wanting to post a thank you to demonrunner, ring and pinion installed and should be on the road by this weekend.
oldblue
Sep 28, 2015 04:07 PM
Ott47
Sep 14, 2015 12:09 PM
Badfish740
Sep 4, 2015 04:21 AM
Gio8
Aug 27, 2015 12:14 PM
rjtrials
Aug 6, 2015 07:25 PM
