Master Cylinder leaking for mystery Screw
Old Nov 5, 2013 | 10:15 AM
Woogies's Avatar
So I noticed a nice spot of brake fluid under my car; after banging my head against the wall a few times I found that the leakage appears to be originating from the screw between the two lines (see photo). This was a brand new cylinder, bad copper gasket? Any suggestions? It's fairly tight already
I've already contacted the manufacturer to see what they can do. I'm assuming I can get a new gasket, but I'm really trying to figure out what that screw is for (Bleed screw maybe?).
Old Nov 5, 2013 | 10:32 AM
RustBucket's Avatar
Your MC actually has 2 pistons that work in series. I think that screw holds them in place after assembly. I personally would not feel comfortable removing it for any reason.
Is that a 15/16" MC? I've got a nice rusty non-leaking one that you're welcome to
Old Nov 5, 2013 | 10:38 AM
Woogies's Avatar
It does have two pistons, and that wasn't the answer I wanted :/ ... As stated in the earlier post, it's actually a 1" but it was suppose to be a 7/8". Certainly been a thorn in my ass. I may have to take you up on that offer.
Old Nov 5, 2013 | 12:11 PM
ksti's Avatar
You probably won't want to hear this either, but after reading numerous threads/posts regarding your master cylinder change, ie; pedal travel, pressure that doesn't seem right, leaking, etc, etc.
IMHO I would contact whom ever you purchased the master from and see if you can return it.
Being you have a 2WD and no other brake mods I just think it would be to your benefit to use 7/8 bore size master cylinder that is for your application.
You won't have to adjust pedal travel, you shouldn't have to bleed entire system or mess with LSPV if it even has one.
Just a suggestion/good luck
P.S. No insult to RustBucket, I think it was a nice gesture
Old Nov 5, 2013 | 01:49 PM
RustBucket's Avatar
If that's a new MC, yeah, take that sucker back!
Old Nov 6, 2013 | 10:10 AM
Woogies's Avatar
Alright I caved... I'm working on getting the 1" one returned. I have the correct sized replacement in the mail. For future reference rustybucket was correct; according the Cardone that screw keeps the #1 cylinder in place.
jasonty
41
Dec 23, 2018 01:00 PM
raptor510
Feb 17, 2017 07:11 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
HookahRoo
Jul 20, 2015 07:06 PM
Jonny246
Jul 12, 2015 04:51 AM
