Truck Not Starting...
Old Nov 10, 2013 | 04:44 PM
The Tick's Avatar
Angry Truck Not Starting...
So I bought a 1st gen 4runner the other day. Long story short, I got it home just fine (a 2 hour drive), no problems at all, but the next morning it would not start (the engine would turn over, but not start). That afternoon I got it started by being towed behind my bro's suburban and popping the clutch in second. The first time we pulled it, it started just fine, but as soon as the engine went down to idle, it stalled, so I tried it again, and got it started and in the garage by giving it a bit of throttle and not letting it idle.
I was wondering what you guys thought the problem was. It won't start, and it won't idle, but it will run if you give it a little throttle while it is running. Thanks!
Old Nov 10, 2013 | 05:50 PM
The Tick's Avatar
I know that this could be one of very many things, so let me know if you need more info.
Old Nov 10, 2013 | 06:00 PM
ksti's Avatar
First two things I would check that all ground wires are clean and tight and for vacuum leaks, possible hose disconnected or worn.
Old Nov 10, 2013 | 06:13 PM
The Tick's Avatar
I thought that if the ground wires weren't connected, it wouldn't run at all. I'll check those things. Thank you.
Old Nov 10, 2013 | 06:30 PM
jb451's Avatar
I agree, that sounds like it may be a hose or something (if you were able to move it by giving it light throttle, i'd think you had a lean condition at idle.), but for it not to start, it'd have to be a HUGE leak, like you were missing 4 or 5 hoses. I left a few of mine off by accident and mine started, but ran like crap.
Old Nov 10, 2013 | 07:32 PM
The Tick's Avatar
You were right! It was the ground going to the igniter (I think that's what it was) that was disconnected. Thank you so much! My baby lives!
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
thelifeadventure
Jul 2, 2015 03:09 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
