need trailer hitch
Old Nov 11, 2013 | 02:23 PM
madmawler's Avatar
Question need trailer hitch
I just bought a 94 4Runner a few weeks ago. It is a 2wd with 3.0 v-6 and A/T. The seller had neglected it for a couple of years, including letting the registration lapse since Jan. 2013, and it took a little tlc to get it up and running again. After replacing belts, vacuum lines, fluids, etc., and hosing off all the black widow webs that accumulated underneath it, I could tell that it had been pampered and garaged for most of its life. This is my first 4Runner, and now I am as familiar as everyone else about their Achille's heel, mechanically speaking: the issues with the window in the rear hatch! I will get that worked out, eventually. But my question is: how can I tow my tent trailer with the stock bumper on the rear? Do I need to buy an aftermarket bumper that I can mount a tow ball on, or can I find a hitch made for that specific vehicle that will bolt right on to the frame? Do I need I need to get a hitch custom welded on it, what are my options? This is my first post, and I think I did the right thing by joining this web site. It appears to me that a lot of the members here know their trucks and SUV's inside and out. Any input would highly appreciated. Thank you.
Old Nov 11, 2013 | 02:46 PM
wyoming9's Avatar
Red face
You should be able to find a premade one just do some searching.
A custom built one would likely be more expensive just depends how fast you need one.
In any case it should be bolted on but that is a personal preference .
Just depends what bumper you have on there now a bolt on receiver for a step bumper might be an option
A tent camper can`t be real heavy??
Old Nov 11, 2013 | 02:53 PM
Stetson_md's Avatar
Make a pipe bumper they look better the the stock pos they protect the truck and they are generally strong enough to pull down a house
Old Nov 11, 2013 | 04:10 PM
Chaser Johndoe's Avatar
nice find on the 2wd runner they are kinda rare. lots a companys make trailer hitches for the 4runners. 2wd and 4wd should take the same one.
Old Nov 12, 2013 | 10:57 PM
madmawler's Avatar
Wyoming, Stetson, and Chaser,
Thanks for the advice on bumpers and hitches for my 94 2wd runner. I bought it for my girlfriend originally, but she says it's too slow for her. She has a 94 Ford Ranger 2wd with a 4.0 V-6, which has plenty of power for a small truck. So I guess I'll have to keep the runner for myself. I can live with that. With the 3 liter motor and 235/65/17 tires, I probably won't be able to outrun the LAPD Crown Victorias, but it has more than enough power to pull my featherweight 10' long pop-up tent trailer or my 19' shallow V hull fiberglass ski boat. My runner has 220,000 miles on the original engine, but when I tested the compression, it passed with flying colors. I can get a few more horsepower out of it if I replace the stock air filter with a K & N filter, and I'm guessing it is probably new enough that I can find a chip for the ECU. I live in SoCal, so I should be able to find everything I need for my new project (beefing up my 4runner). Thanks for pointing me in the right direction.
Old Nov 12, 2013 | 11:02 PM
wyoming9's Avatar
Red face
A word to the wise there are no chips for the ecu
If there would be don`t you think they would be sold with a upgraded rebuilt ECU??
I would so love to be proved wrong
Old Nov 13, 2013 | 04:36 AM
The only way you are going to get good power is a 3.4 swap. Also k+n are a waste of money. The stock filter from Toyota is the best you can buy.
Old Nov 13, 2013 | 09:17 AM
Stetson_md's Avatar
Idk about on trucks but on atvs and the k&n filters are known to kill motors because of howmuch dirt the let into the motor sothere recommended for race only
Old Nov 16, 2013 | 12:59 AM
wyoming9's Avatar
Red face
Yes with that engine just run the stock filter. The trick is it needs to be changed when it is needed just don`t go the out of site out of mind.
I use the wix filters on all my engines.
Old Nov 16, 2013 | 01:47 AM
TNRabbit's Avatar
I've had this hitch from etrailer.com for years. Can't beat it. Installation does require removing the rear bumper & reinstalling after the hitch.
http://www.etrailer.com/Trailer-Hitc...cleid=19942317
RyanJ989
11
Apr 7, 2021 09:41 AM
Redeth005
Jun 28, 2018 08:16 PM
Cycles
Sep 29, 2015 06:37 AM
potatopants
Sep 15, 2015 06:26 AM
mirabile4runner
Sep 3, 2015 07:15 AM
