92 V-6 Floods
Old Oct 30, 2013 | 01:26 PM
james.weitman's Avatar
92 V-6 Floods
I just recently purchased this truck and once in every 15-20 times of cranking it acts like it is flooded. I have replaced the cold water sensor and the start injector switch. It is not a constant problem so hard to diagnosis for me not being a mechanic myself. You can let it set for 10-15 minutes and it will fire off. While flooded it smells like old gas, but I have ran 3 tanks thru it and also a bottle of sea foam. Thanks in advance. James
Old Oct 30, 2013 | 04:09 PM
Gamefreakgc's Avatar
It may not be a fuel issue, but rather a spark issue. Are you plugs new?
Could also be a clogged or leaky injector. Try running a couple of injector cleaners.
That's the easy stuff for starters.
gentry
Sep 28, 2015 06:16 AM
SolarImages
Aug 30, 2015 09:28 AM
smooretahoe
Aug 14, 2015 09:23 AM
Motomonty
Aug 9, 2015 05:53 PM
