22re running rough
Old Jan 17, 2006 | 01:12 PM
John79's Avatar
22re running rough
The 22re in my 89 toyota pickup starts right up cold and runs fine but when it warms up it starts running rough when i give it gas while driving it hesitates and stumbles and the check engine light flickers. Does it mostly when I'm driving and step on the gas after its warm the more I drive the worse it seems to get then it will die and not start back up till it cools down. I checked the codes and got 41 and 51 for the tps replaced the tps and still does the same thing. Thinking it might be the fuel filter but I replaced that less then 10k ago when I did the head gasket.
Any ideas?
Old Jan 17, 2006 | 01:22 PM
punkindrublic721's Avatar
you sure it wasnt code 31?
Old Jan 18, 2006 | 12:28 PM
John79's Avatar
nah 41 which is the tps and 51 switch signal. but it seems like something is wrong with the fuel system.
Old Jan 19, 2006 | 12:02 PM
Tiger Paw's Avatar
Check your plug wires. When is the last time they were replaced? If the insulation on them is getting bad, it will cause you're truck to do what it's doing. I was having the same problem and replacing the wires took care of it.
Old Jan 19, 2006 | 05:43 PM
kyle_22r's Avatar
sounds like a TPS problem to me.
Old Jan 21, 2006 | 09:36 AM
John79's Avatar
Turns out it was the plug wires looked like they were the original ones so I replaced them and now its running good again. thanks
Colington
Mar 8, 2020 09:51 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
karbin
Jul 5, 2015 11:37 PM
