Bilstein/Downey HD Combo
Old Aug 9, 2007 | 11:34 AM
mike92runnerSR5's Avatar
Has anyone ever used the Bilstein F4-B46-1469-HO rear shocks with the Downey 48290 HD coils? I have the Bils installed and need to change the coils. My concern is that the Bils are too short for an 1.5" lift coil. Any comments are appreciated. I Have a 2nd gen 4x4 runner. Thanks.
Old Aug 9, 2007 | 11:49 AM
ewong's Avatar
not directly relevent...
I ran OEM sized Bilstien HDs on a truck with a 1-2" lift Deaver leaf spring Gen1 4Runner.
The shocks installed had about 1" of droop
The truck would "buck" when the rear axle unloaded(off the ground)
It also (IMHO) adds extra stress to the shock (top out is bad - esp if top out also has to constrain the suspension...
I dont have the bilstien catalog handy to see what the specs of the shocks that Downey reccomends be used with their springs.. that will tell you more about what is and is not workable.
Im now running a longer (58?) Alcan/AOR Orbit eye (front eye only) spring and using 7100 series Bilstiens witha 10" stroke in a short body (remot res required)... much better
Old Aug 9, 2007 | 12:00 PM
yea..I called Bilstein today and the rep couldn't tell me if they would be long enough for the Downey 1.5" lift coils..I know theres an install write up of the same combo but it doesn't give the Bils #. I also know the 5100's are longer but it's too late for those..
Old Aug 9, 2007 | 12:25 PM
4Runner92sr5's Avatar
the OME 901's are better IMHO and i have a pair for sell that only have 5K miles on them if your interested it would be cheaper then new ones
Old Aug 9, 2007 | 12:27 PM
ewong's Avatar
Downey site
Link to suspension page
http://www.downeyoff-road.com/Suspen...ents/index.htm
Text -
We have developed a set of rear coil springs that offer higher ground clearance and increase tire travel, without giving up a comfortable ride. This new coil set raises the vehicle 1. The springs have a larger diameter which is offset by their length to equal a stock spring rate. The coils are powder painted and include a longer stainless steel braided brake line, proportioning rod remounting bracket, ABS hose remounting bracket, and detailed installation instructions.We have also responded to numerous request for a heavier duty set of rear coils for load haulers, trailer towers, or those using the 20 gallon auxiliary tank. These new coils are 20% heavier duty, and give the same 1 of lift. Either set of coils use Doetsch-Tech #8250D or 4MV09-SL shocks (shocks not included).
Doetsch Tech site
link to specs
http://www.doetsch-shocks.com/37.asp
8250 ---> 22.5" to 13.5"
At home I have an old Bisltien print catalog that had a spec chart.
Its not on their web site
WHen I cant use that I use the Rancho catalog to cross ref the specs
Rancho Master Catalog
http://www.gorancho.com/html/product...ho_Catalog.pdf
OEM shcoks specs on page 74
90-95 with 0-1" of lift uses on the rear RS5187
Shock specs start on page 165
5187 --> 20.75" - 13.00" (bump stop unit - specs at bump contact)
Call bistien back - get the extended and compressed lenghts
Old Aug 9, 2007 | 12:51 PM
I'll have to give Bilstein a call back as you suggest and I'll find out the length specs..so if they are the same as the doetsch specs (22.5" - 13.5") I should be okay to use the Downey HD's...thanks..
Old Aug 9, 2007 | 01:07 PM
ChickenLover's Avatar
I'm running Downey HDs and the bils you've mentioned. I've had no problems. On a side note; the ride is absolutely perfect.
Old Aug 9, 2007 | 01:12 PM
4x4CPOSEADOG's Avatar
I have the same Billies/Downey HD coils for almost two to three years now and I do not have a problem and the ride is perfect. I have a little bit of nose down but it will be even out once the rear is loaded with heavy crap.
Old Aug 9, 2007 | 06:10 PM
thanks for the info..sounds like it's a go...has anyone seen the Downey HD package for the 2nd gens cheaper than $197.00 as advertised by Downey direct? found $189.99 from Central 4WD.
joeynational
Sep 5, 2015 01:54 PM
travisamorgan
Sep 2, 2015 01:00 PM
Jgloade
Aug 29, 2015 08:40 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
Athansinis
Jul 27, 2015 08:38 AM
