Help me identify my T-Case
Old Aug 9, 2007 | 09:12 AM
lqdKaos's Avatar
I just purchased a 1989 4Runner SR5 V6 with a 5 speed transmission. From what I have read, I think I have the chain drive T-Case. Am I correct or do I have a gear drive?
I have a 1985 donor truck that I was going to pull axel, t-case, etc... I want to run dual cases, but want to know if I need to purchase another t-case or can I use the two I have.
Thanks
Old Aug 9, 2007 | 10:17 AM
tc's Avatar
tc
V6 has chain drive case
You need a V6 adapter to use the gear drive crawl box off the '85 and then an MC10 from Marlin Crawler to adapt the gear drive crawlbox to your chaindrive case. It is several hundred bucks cheaper to do it this way than to do dual geardrive cases.
I was going to do it this way, but found a used geardrive setup.
Old Aug 9, 2007 | 10:19 AM
tc's Avatar
tc
NOTE: before everyone chimes in and says the chaindrive case won't hold up...
- this case is behind the strongest tranny Toyota makes. Don't you think they would have used similar design requirements?
- chain drive cases are holding up just fine in MANY Tacomas (and even some Tundras) with dual cases (and in some cases superchargers) making a helluva lot more power than we're ever gonna dream about making in a 3.0.
Old Aug 9, 2007 | 10:26 AM
4Crawler's Avatar
You can find out when case with the information on Marlin's web site:
- http://www.marlincrawler.com/htm/tra...earvschain.htm
- http://www.marlincrawler.com/htm/tra...ansfercase.htm
Not sure if there is an adapter for mating those two cases, if Marlin doesn't have one, try InchWOrm:
- http://www.inchwormgear.com/store/in...bc2739c24f693d
ClintonP929
3.4 Swaps
64
Jun 13, 2017 01:46 PM
JUICE222
Oct 13, 2015 08:50 AM
Bill854x4
Sep 20, 2015 04:32 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
