help with codes + a popped fuse
Old Aug 5, 2007 | 10:38 AM
isaac338's Avatar
I was poking around under the dash fixing the PO's terrible stereo wiring job when I noticed the IGN 7.5A fuse was popped. The truck was running fine, maybe hesitating a small amount, but was getting terrible economy (like 350-400km on the highway to a tank of gas). I replaced the fuse and the truck feels like it's running a bit smoother but it's too early to tell if it affects the economy. From what I can gather in the wiring diagram the IGN fuse controls the charge light and the emissions computer and related things (like fuel cutoff, VSV, and so charcoal canister and everything). Presumably that was the problem with my crappy mileage, am I right?
So while I was working I pulled the codes and got a 14, 41, and 51. I then pulled the EFI fuse for a minute and the 14 and 41 went away (presumably due to the new IGN fuse). The 51 remained, but I can't find it listed in my Haynes manual. What's a code 51?
This is on my 89 4Runner.
Old Aug 5, 2007 | 11:30 AM
olharleyman's Avatar
According to my list they are as follows
System Affected Probale Cause
14 Ignition Signal Ignition Coil , Ignitor Or Circut ,ECU
41 TPS Signal TPS Or Circut , ECU
51 Switch Signal Accelerator Pedal Or cable A/C Switch Circut , A/C Amplifier ,ECU , Neutral/ Start Switch or Circut TPS Sensor Or Circut
Hope this helps As for what to do I would start by pulling the pos battery cable and leave it off for about 1 min then replace it and run the truck and see if you get the code/s again and then start narrowing it down from the list as shown.
Old Aug 5, 2007 | 04:28 PM
isaac338's Avatar
As I said, I reset the ECU and the only code left is 51. In the FSM it seems like it's a code thrown if you're not in Neutral or the like when you jump the diag terminals. Am I right?
Old Aug 5, 2007 | 04:32 PM
superjoe83's Avatar
51 means most likely you tps is out of adjustment
Old Aug 6, 2007 | 09:48 AM
isaac338's Avatar
which it likely is. i'll pull the throttle body and clean/adjust it. thanks!
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Feb 26, 2017 07:07 AM
JHalcyonM
Aug 4, 2015 01:19 PM
PlayAwhile
Jul 20, 2015 11:36 AM
rushw
Jul 18, 2015 01:46 PM
