Engine/transmission separation problem
Old Aug 5, 2007 | 10:04 PM
runethechamp's Avatar
Sooo, why are they still stuck together when I try to lift out the engine in my 4runner? I'm sure I got to all the bolts holding them together, and they even separate a little bit on the driver's side. My only guess is that I need to take out the starter first, although it doesn't look like I need to on the sketches in the FSM. Is that it, or is there anything else I need to do down there?
Old Aug 5, 2007 | 10:30 PM
ewong's Avatar
yup - starter out
also theres a bolt going in the REVERSE direction down on the drivers side on the 22RE/W56 setup...
It has to be pulled back first as the snout hangs up on the clutch disk
(or in your case - pulled forward)
Old Aug 5, 2007 | 10:32 PM
Originally Posted by ewong
yup - starter out
Thanks for the confirmation. I have the 3vze/r150, so I don't think I have that reverse bolt.
Old Aug 5, 2007 | 10:46 PM
ewong's Avatar
The starter sandwiches the splash plate to the bell housing.
The splash plate is bolted to the engine block
The bell housing is bolted to the trans
Its not coming apart w/o the starter out....
Old Aug 5, 2007 | 11:18 PM
drew303's Avatar
I'd drop the transmission alltogether... its not that difficult to get them back up in there... besides how are you supporting the transmission when the engine is out anyways? jackstand?
88sasturbotoy
Jan 30, 2026 01:57 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
msane99
Jul 17, 2015 10:13 AM
