Fiberglass Q - making a cab floor
I guess this Q is for Slacker / Toyota Fiberglass
The first project is a trans tunnel cover.
The idea is to make a DIFFERENT trans tunnel to deal with
-- flat belly?
-- trans brake
-- dual case
-- triple stick (needs clearance)
-- R151 swap (its further forward)
The thought was that I could
add some foam etc to the top of the tunnel
carve it to the shape I wanted
smooth it
pull a mold
cut the tunnel out
pull a part from the mold
rivit the part back to the floor
Assuming I space the rivits close together etc.. (say every 1in or so) will the tunnel would be strong enough?
People on Pirate4x4 think the tunnel will crack.
Seeing what your beds do - I think that it depends on the Mat and Resins used..
So Q: good idea or bad
The second project is to make an entire floor section and rivit it in to the good parts of the OEM metal.
Is that even feasible? Or is it really necessary to add metal reinforcements?
-- flat belly?
-- trans brake
-- dual case
smooth it
pull a mold
cut the tunnel out
Johntom240
7
07-13-2015 12:18 AM
FS[NorAtl]: 1989 pickup beds and leer cap Rhode island
mickyd9990
07-06-2015 09:01 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
