Hilux LSD diff installed now vibration
Old Apr 13, 2006 | 10:06 PM
NC-B17A's Avatar
I got a Hilux LSD diff for my 90 4runner with 4.88's. We installed it now I have a vibration up until around 25 mph its not as bad with the clutch pressed in coasting. & gets worse when I accelerate harder in the mph range.
Everything is tight I flipped the driveshaft 180* & no change. The diff has fluid we checked it today.
I have searched & have not found a problem like mine with a solution. Other then the diff having a prob is ther anything else that I could check?
Thanks for any ideas :pat:
Old Apr 14, 2006 | 04:21 AM
Yoda's Avatar
tires are the same size on both sides? Did you use the LSD oil package? Does it have a bent pinion?
You could remove the rear DS and drive it in 4X4 see if the vibe goes away.
Old Apr 14, 2006 | 11:01 AM
NC-B17A's Avatar
I spun the pinion around before we put it in & it was fine. I put Lucas 90w & added one tube of LSD additive when I filled it up.
I have not taken the driveshaft out & driven it but I will in a few mins to see if that does anything. I am going to spin the shaft on the splins on the transfere case to see if that helps.
& yes the tires are the same on both sides.
Old Apr 14, 2006 | 01:17 PM
AH64ID's Avatar
Did a shop do the install?
Old Apr 14, 2006 | 06:26 PM
NC-B17A's Avatar
no a friend & I did the install.
I figured it out what was going on. I spun the driveshaft on the transfer case & the vibration is down to a very min. its all good
thanks for the help though
Old Apr 14, 2006 | 06:49 PM
waskillywabbit's Avatar
Might try it in all four rotated bolt patterns and see which one is best or the least vibration.
jerusry
Oct 19, 2015 05:28 PM
jaretstuff
Aug 4, 2015 02:08 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
