Oil pressure guage
Old Apr 13, 2006 | 11:21 AM
T78's Avatar
T78
Oil pressure guage
Okay, I want to install a oil pressure guage in my 88 4Runner. So I need to know what switch to pull on the 22Re. There is one right below the oil filter that has one wire going to it and then another that is right beside the oil filter with a yellow plug with some wires going to it.-Zach
Old Apr 13, 2006 | 05:50 PM
bustah49's Avatar
the one to the lef with a yellow plug is the knock sensor.
the one under the oil filter is the one you want.
Old Apr 13, 2006 | 06:49 PM
T78's Avatar
T78
Thanks, Yeah I should of just looked on the net before I posted this cause I found in pretty fast. The bad thing is that I went to take it out and it sheared right off :cry: . So I went and bought a easy out to get the shank out and sure as Sh%!T I busted that in there . I know them things are almost impossible to get out so not sure what I'm going to do with it. I can't afford to take the engine out and take it to a machine shop. I might drill aorund it and try to tap the hole (which is what I shoulda done the first time around). If could I just weld it shut and wait till I get a new engine?
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
