torsion bar on the driver side
Old Apr 13, 2006 | 10:22 PM
jeepin_al's Avatar
I am trying to uncrank a huge torsion crank from my truck that the previous owner put on. I was able to get the passenger side undone (some) but the driver side I can't get enough torque on the bolt and can't get anything bigger or a rachet on it. I read the write up but it doesn't actually say how to do it. thanks. AL
Old Apr 13, 2006 | 10:23 PM
CoedNaked's Avatar
Have you tried using a "cheater?"
Old Apr 14, 2006 | 12:21 AM
deathrunner's Avatar
Be careful dude, Those bolts can snap and completely unload the suspension. It is recommended that you uncrank it with the car lifted off the ground. That way there is no pressure exerted on the sytem. That will make it easier.
You might also want to try some penetrant on the bolts
Old Apr 14, 2006 | 03:43 AM
mt_goat's Avatar
X2...get that wheel off the ground, full droop.
Old Apr 14, 2006 | 11:32 AM
Bobakazi's Avatar
X3. And let the penetrant sit for several minutes.
Old Apr 14, 2006 | 01:11 PM
AH64ID's Avatar
x4, why not?
Old Apr 14, 2006 | 02:56 PM
tc's Avatar
tc
x5 and after you let the penetrant sit several minutes, hit it again with some more
Old Apr 14, 2006 | 04:08 PM
91_4x4runner's Avatar
x6 to go with the new 'fad' and to wish good luck
Old Apr 14, 2006 | 04:21 PM
AH64ID's Avatar
would it be wrong it I went x7, since I already did x4??
Seriously, I had a similar thing happen when I was trying to pull the stock T-bars off my 92, snapped the bolt...pretty cheap from toyota, might want to order one first incase you break it if its your DD..
Old Apr 14, 2006 | 05:26 PM
jeepin_al's Avatar
It is sitting on jack stands and I have hit it with lubricant for a few days in a row. I can't fit a cheater bar in there to get more leverage.
Old Apr 14, 2006 | 11:10 PM
AH64ID's Avatar
The part you want to turn is on the bottom, there shouldnt be a clerance issue at all....
Old Apr 16, 2006 | 08:24 AM
Originally Posted by mt_goat
X2
Originally Posted by Bobakazi
X3
Originally Posted by 4x4nala
X4
Originally Posted by tc
X5
Originally Posted by 91_4x4runner
X6
What is this? Math Class?
thefishguy77
Jul 30, 2015 10:59 AM
coffey50
Jul 28, 2015 10:55 AM
CanRunner
Jul 20, 2015 01:29 PM
msane99
Jul 17, 2015 10:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
