Drain block of antifreez to drain heads
Old Apr 19, 2006 | 06:22 PM
jjenks0's Avatar
I am taking the heads off of my 3.0 and am wondering if there are any drains on the block. From past experience it seems when you pull the heads a bunch of antifreeze gets in the cylinders.
Old Apr 19, 2006 | 06:35 PM
PhiHalcyon's Avatar
Here you go.
Old Apr 21, 2006 | 08:52 AM
Radyota's Avatar
I drained the radiator, then pulled off the lower rad hose and thermostat/housing. Also pulled off the little hose on the right side of the thermostat/water pump that goes to the oil cooler and lowered it to drain the block. I got absolutely no antifreeze in the cylinders when I pulled my heads off.
Old Apr 21, 2006 | 06:57 PM
miket223's Avatar
Good luck getting to those block drain plugs with the engine mounts bolted to the block.
Old Apr 21, 2006 | 07:24 PM
jjenks0's Avatar
Thanks for all of the suggestions
o2raybid
Sep 4, 2015 12:45 PM
toofly1999
Jul 25, 2015 07:09 PM
kcaudill
Jul 20, 2015 12:06 PM
Coreyr384
Jul 10, 2015 11:13 AM
Gamble_STi
Jul 7, 2015 07:54 PM
