Tranny leak
Old Apr 11, 2006 | 09:30 PM
shodobe's Avatar
Tranny leak
I have a '92 runner with about 250,000 on it. Early last year I took it in for a routine maintenance on the tranny. No problem until about a month later when I noticed a leak, never had one before. The place that did the original work told me the tranny was in need of a rebuild because the leak couldn't be fixed. Now, I also had the engine top end rebuilt just last month after it sat for almost a year and the guys who do all my work also said the leak couldn't be fixed without a rebuild or ? The tranny leaks a little in drive but much worse when in reverse. I know I need to do something about this soon but really can't since I just put out alot on the engine rebuild. My question is would it be better to rebuild or get a used one? The first guys quoted me about $800 where my regular guys said it would be fairly costly for them to do it. Is there something I can add to the tranny to slow down the leak or maybe there is a loose bolt I can tighten down? I would like this to wait for at least 6 months but would also like to drive it. Any suggestions would greatly appreciated. Thanks Mike
Old Apr 11, 2006 | 09:32 PM
Elton's Avatar
where is it leaking from
Old Apr 11, 2006 | 09:37 PM
shodobe's Avatar
I not really sure but it seems to be coming from the rear of the tranny right where the skid plate is.
Old Apr 11, 2006 | 09:40 PM
Elton's Avatar
could be the seals are bad and are in need of replacment and that should solve the problem
Old Apr 12, 2006 | 07:52 AM
toyotaoffroad91's Avatar
holy moly find a new mechanic. check the cooler lines being that you said reverse is worse. reverse requires i think 125 psi to get that baby to go backwords. or check the seals. remove one of the bolts that goto the tranny/transfercase if the rear out put is leaking you will see fluid appear. or if ya got an a340h check the pinoin seal
Old Apr 12, 2006 | 07:35 PM
shodobe's Avatar
If this is the problem then should the tranny need to be re-built or can the seals be replaced with minor(somewhat) repairs?
Old Apr 12, 2006 | 08:15 PM
Elton's Avatar
i think its just a matter of putting new front and rear seals in if there wasint any thing wrong with the tranny besides the leak
Dieselmann
Feb 19, 2019 02:57 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
yourrealdad
Jul 29, 2015 11:08 AM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
