One man clutch bleed
Old May 25, 2014 | 02:20 PM
mantree's Avatar
I just replaced my clutch slave on my 22re because I was toping up the master every week and my clutch wasn't disengaging all the way. When I got my new slave I picked up a speed bleeder and bleeding the system took 5 min with no help. They come in a pack I 2 for $15 with a part number 12709 from autozone. After this I think I will put speed bleeders on all 4 brakes. I do all my repairs on the road or in parking lots because i live in a apartment.
Old May 25, 2014 | 03:30 PM
Teuf's Avatar
I did it alone also, pump pump pump hold pedal with a stick, run around bleed x 10 times or so. Oh and keep the fluid level full, cost 0. But sounds interesting. i think i'll check it out.
Old May 25, 2014 | 03:37 PM
mantree's Avatar
The advantage of the speed bleeder is that it has a check valve in it so you don't have to shut it between pumps and you don't have to wory about sucking air back in.
Old May 25, 2014 | 04:01 PM
HighLux's Avatar
Tuef...I did the trekker one alone....was tricky...pretty much how you said...lol.
Old May 25, 2014 | 07:19 PM
Teuf's Avatar
Yea I had taken the drivers seat out just to get up in there to access the clutch slave. So a stick fit against the cab back perfectly.
Old May 26, 2014 | 02:30 PM
Robert m's Avatar
dont forget about the bleeder in the LSPV too
Old May 26, 2014 | 03:50 PM
jbtvt's Avatar
Yup, PITA. Anyone have experience with a power bleeder kit that comes with adapters that fit Toyota clutch and brake masters?
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
choppe777
May 16, 2016 08:00 AM
Scatterbrain
Sep 27, 2015 08:24 AM
scheuvront1993
Sep 17, 2015 06:17 PM
old87yota
Sep 9, 2015 12:39 PM
