22re starting problem
Old Jun 4, 2014 | 05:28 AM
fish4fun's Avatar
i have a 86 4runner with a newly rebuild 22re. about a week ago it just stopped turning on. it gets no power when i turn the key forward. so i had the battery checked and its fine.heres the strange thing, if i jump it the engine cranks right up no problems.is this a fuse problem,or some sort of wire connection? any ideas guys?
Old Jun 4, 2014 | 05:32 AM
InToxicOne's Avatar
It may be the starter relay. Also check your battery and all ground/electrical connections for any signs of corrosion. You may have a rusty bolt that could cause the connection to be too weak to generate your cranking power.
Old Jun 4, 2014 | 09:21 AM
fish4fun's Avatar
i have replaced the ground wires, starter cable and started relay already.
Old Jun 4, 2014 | 10:48 AM
RJR's Avatar
RJR
Check out this post https://www.yotatech.com/forums/f116.../#post52171407
and this one
https://www.yotatech.com/forums/f116.../#post52166219
to zero in on where the problem is.
Crazychris1871
Jun 27, 2016 10:38 AM
jennygirl
Nov 17, 2015 11:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Sandman
Jul 23, 2015 08:15 PM
Old Red 94
Jun 16, 2015 08:32 PM
