Dash Lights After Disconnecting Cold Start Injector
Old May 28, 2014 | 05:00 PM
90YotaPU's Avatar
So after checking pretty much everything else and still getting lousy gas mileage and having a strong gas smell at idle, i decided to disconnect the plug to my cold start injector (thinking it is always stuck open). Truck cranked a little longer than usual, but once started, ran fine in both open and closed loop. What was odd is that after getting off the highway, at idle, the Parking Brake, A/T Oil Temp, and the Battery Light came on. When I started moving again, the lights went out. At the next traffic light, they came back on. Anyone else experienced this and have any insight?
Old May 28, 2014 | 11:03 PM
RAD4Runner's Avatar
Originally Posted by 90YotaPU
... What was odd is that after getting off the highway, at idle, the Parking Brake, A/T Oil Temp, and the Battery Light came on....
Charging system fault, when "L" signal of alternator goes low, will cause all three of the above lights to come on.
Grab a multi-meter and check your charging system according to this.
Best of luck.
Old May 29, 2014 | 06:28 PM
90YotaPU's Avatar
Best of luck.
Thanks for the help! I will take a look at it this weekend.
Old May 29, 2014 | 07:40 PM
RJR's Avatar
RJR
RAD4Runner is likely correct. As far as why the lights started coming on after you disconnected the CSI, it may simply be because the truck is now idling at a lower rpm and the alternator can't charge the battery at such a low speed. A good sign that your charging system needs attention.
Old May 30, 2014 | 02:22 AM
90YotaPU's Avatar
That's exactly what I was thinking. The alternator looks pretty bad (noticed it before), but it never made any noise, so I left it alone.
Regency
20
Jan 3, 2020 07:43 PM
Valvoman
Jun 28, 2015 02:45 PM
Taz22R
Jun 21, 2015 04:44 PM
jmc88runner
Jun 18, 2015 03:39 PM
