Dash Lights After Disconnecting Cold Start Injector
So after checking pretty much everything else and still getting lousy gas mileage and having a strong gas smell at idle, i decided to disconnect the plug to my cold start injector (thinking it is always stuck open). Truck cranked a little longer than usual, but once started, ran fine in both open and closed loop. What was odd is that after getting off the highway, at idle, the Parking Brake, A/T Oil Temp, and the Battery Light came on. When I started moving again, the lights went out. At the next traffic light, they came back on. Anyone else experienced this and have any insight?
RAD4Runner is likely correct. As far as why the lights started coming on after you disconnected the CSI, it may simply be because the truck is now idling at a lower rpm and the alternator can't charge the battery at such a low speed. A good sign that your charging system needs attention.
Regency
20
01-03-2020 07:43 PM
jmc88runner
06-18-2015 03:39 PM
