3VZE High/fluctuating idle at running temp
Old May 31, 2014 | 04:08 PM
nducci's Avatar
I have a 3vze that has been recently rebuilt. I had a problem with the power steering pump air control valve leaking fluid back into the intake. I replaced the valve with a bolt and close the vacuum line circuit. I haven't notice any performance in the power steering at idle which is all the valve did from my understanding. It has run like a champ since but has uncovered another issue which i think the PS fluid through the intake was suppressing. It now idles high, around 1500-2000 Rpm, even when it is warm. Except, once and a while the idle will drop down to between 500-1000 rpm that it should be.
Im trying to troubleshoot it quick since I have to flip it before the fishing season starts. Anybody know whats going on here.. simple adjustment to idle screws or replacing the IAC valve? Thanks
Charecter1
Nov 6, 2023 10:08 AM
smiley52
Jul 11, 2015 05:16 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
