Rear end mona/droan/hum? i dunno, help please?
Old Jun 25, 2013 | 06:38 AM
bbrideau's Avatar
so its mainly predominant at highway speeds but i can feel it in my seat and hear it coming from the rear of the truck. its a very low rumble and it droans. it goes hummm hummm hummm. I did notice my fill plug on my rear dif has some signs of leakage. i have not checked the fluid level yet but could that just be a result of low fluid? my u joints are solid. no play in them. clutch has less than 1000 miles on it and the same with the top end rebuild. my front end is also brand new alignment is perfect. The tires are old and are starting to crack so i have not ruled out the tires. My fear is that my third is going, any thoughts? Thanks in advance YTer's!
Old Jun 25, 2013 | 06:53 AM
YotaWoRx's Avatar
Rear axle bearings?
Old Jun 25, 2013 | 07:06 AM
bbrideau's Avatar
thats another thing i could look at. thanks, hopefully its just the tires/low diff fluid.
Old Jun 25, 2013 | 09:02 AM
SPARKS89's Avatar
x2 on the axle bearing. Do you notice it more when your on the gas or off the gas or does it matter?
Old Jun 25, 2013 | 09:08 AM
bbrideau's Avatar
its more pronounced when on the gas but still there when off the gas. the faster i go the louder it gets, can start to hear it at about 75-80 km/hr so about 45mph.
Old Jun 25, 2013 | 10:30 AM
Discombobulated's Avatar
Mine started humming at 60+ same thing your talking about and yes both bearings were shot Good luck
Old Jun 25, 2013 | 11:48 AM
SPARKS89's Avatar
Sounds like axle bearings. I've had pinion bearings go bad that sounded fine while I was on the gas, but when I let off it was HORRIBLE.
the1998sr5
15
Jul 14, 2020 08:35 PM
Daneums
Aug 20, 2015 05:36 AM
rondogracing
Jul 14, 2015 07:00 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
