EGR Valve?
Old Jul 4, 2013 | 10:00 AM
737IP's Avatar
EGR Valve?
I think this may be part of the EGR valve. It is aft of the EGR on the passenger side. I notice the plastic cover is completely off. The screws came out. Would this cause a code 71 ERG?
Also, how many bolts hold this on so I can remove and repair?
Thanks
Old Jul 4, 2013 | 10:40 AM
yodafan93's Avatar
motor, year, model of the vehicle?
Old Jul 4, 2013 | 10:53 AM
737IP's Avatar
94 SR5 with the 3.0.
Old Jul 4, 2013 | 11:23 AM
scope103's Avatar
PAIR. http://personal.utulsa.edu/~nathan-b...78pulsedse.pdf
Not part of the EGR system, but a vital part of your truck nonetheless.
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf page EG2-57
Use 5mm x 10 socket-head screws, and you don't have to remove anything to reassemble the valve (you can get in there with a hex-wrench).
Old Jul 4, 2013 | 11:40 AM
737IP's Avatar
Great information. Thank you. I take it then this is not responsible for my EGR code?
Old Jul 4, 2013 | 01:09 PM
scope103's Avatar
Probably not. Of course, it is broken, and not difficult to fix, so does it really matter if it's the cause?
Once you put in the four screws, I would suggest following the diagnostics in the manual. http://personal.utulsa.edu/~nathan-b...77exhaustg.pdf
Old Jul 4, 2013 | 01:28 PM
737IP's Avatar
Of course it matters if it is the cause. If this is not the cause it means I need to continue troubleshooting. Right?
Thanks for your help.
Old Jul 4, 2013 | 02:19 PM
scope103's Avatar
Yes, it definitely matters if it is "the cause." Then you would fix it.
But even if it isn't the cause, you need to fix it.
So it doesn't matter either way: you need to fix it.
Old Jul 4, 2013 | 02:51 PM
737IP's Avatar
Listen, I don't want to get into a tit for tat with you. Nowhere did I imply I would not "fix it". I am trying to determine the cause for my code.
You very helpful with the information you provided. Let's leave it at that.
Old Jul 5, 2013 | 06:41 AM
Gamefreakgc's Avatar
Whoa there, calm down!
I think you took scope's comment the wrong way. He's helped me personally several times and has lots of good info. I don't think he was questioning your judgement abilities on whether to fix it or not.
That being said, the PAIR valve does affect emissions along with the EGR. There's no CEL for a broken PAIR, so the ECU might be confusing the readings it's getting from the EGR into thinking that's the issue. I would not be surprised if when fixed (and after removing your EFI fuse in the engine bay fuse box for 1 min) your code 71 never shows up again. However if if does come back, then you most definitely have a busted EGR valve (or gas temp sensor).
Old Jul 5, 2013 | 08:16 PM
Punchy's Avatar
Code 71 is the EGR temp sensor not sensing a change after a set amount of time.
Cause to look into are bad EGR modulator, bad EGR valve, green VSV blocked, vacuum lines to VSV connected wrong, the EGR tube plugged or the EGR temp sensor is faulty in some way.
The PAIR or AS valve just allows atmosphere to enter during decalleration, Its an exhaust leak if just left open like that.
just get replacement screws to close it.
But make sure the reed is still in it or it will cause you problems by allowing the engine to pull innert gasses into the airfilter.
Old Jul 6, 2013 | 06:22 AM
737IP's Avatar
idadan208
Sep 7, 2015 09:06 AM
Scatterbrain
Sep 3, 2015 06:46 PM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
