Cyl#3 not firing
Probably. All three injectors are wired together to "#10" on the ECM.
But that means #3 is "already" jumpered to 1 and 5; you just have a wiring problem right next to the injector if you're not getting the signal at the connector. If it were mine, I'd get the wire bundle to where I can work on it, then carefully unwrap it.
smilen724
13
Nov 8, 2015 04:11 PM
