Help. Need to know if an engine swap will work!
Old Jul 13, 2013 | 09:36 AM
cregs1119's Avatar
Okay so here's the deal. I need to know if a 5sfe will bolt onto a tranny for a 92 tranny. I've been searching and can't find anything that says yea or no. I know it's a motor that sits sideways but in some applications it runs awd vehicles. Can anyone lend any helpful info?
Old Jul 13, 2013 | 09:51 AM
bone collector's Avatar
which 92 tranny? auto or manual? are you taking out a 4 cyl or a 6 cyl?
Old Jul 13, 2013 | 09:53 AM
cregs1119's Avatar
The motor that was in the 92 is a 3vz.
cregs1119's Avatar
Sorry and its a standard tranny
Old Jul 13, 2013 | 10:43 AM
cregs1119's Avatar
It looks like the tranny still bolts to the rear of the motor, it's just whether the bolt pattern will match up
Old Jul 13, 2013 | 10:48 AM
google it..... will your input shaft and splines work with the motor?? bolt pattern and starter work??? you will probably need an adapter plate at the minimum. do some research... read, search, read some more. it probably is too costly and has too many disadvantages for it to become a popular swap like the 5vze or 7mge.
Old Jul 13, 2013 | 10:54 AM
not only that. you will probably have to get new motor mounts welded to the frame. I am assuming you have a 4wd truck based on your avatar. with the front drive shaft hit the oil pan?? what electronics will you have to switch over?? your 92 truck has OBD I computer but Im willing to bet the 5sfe is OBD II (although im not for certain) so how much wiring and computer work will you have to do?? there are probably a million other details I am forgetting about right now. I am in no way telling you not to do this, im just trying to get you prepared for the long road ahead. Google will definitely be you friend. good luck!
cregs1119's Avatar
I have been researching all morning. I can't find anything where anyone has done that sort if swap. I don't know if I could possibly just be typing in the wrong search words or what but I haven't been able to find what I'm looking for.
Old Jul 13, 2013 | 10:57 AM
cregs1119's Avatar
Yea well the frame I have is actually for an 80 model. So motor mounts will definitely have to be rewelded. The guy who is selling the motor is scrapping the car and will give me the ECM and whatever else I need to make the motor run.
Old Jul 14, 2013 | 05:10 PM
cregs1119's Avatar
So that motor swap will not work. Nothing I saw will accommodate a 4 wheel drive transmission.
JF9243176
Oct 8, 2017 04:21 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
noahstancik
Jul 10, 2015 11:18 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
gog1968
Jun 22, 2015 05:55 AM
