Intermittent starting issue: 86 4Runner 22RE
Old Jul 4, 2013 | 09:47 AM
Dell Martin's Avatar
When turning key to start truck (1986 22R-E,EFI-4runner), it clicks several times until it starts( sometimes it does not click, and sometimes it does). sounds like starter clicking, but have replaced the starter, and battery, and ECM, (all visible connections seem to be in order).Could this be starter relay issues, or possibly ignition switch failure?
I am really afraid to turn engine off once I start it (never knowing if it will start again)?
Old Jul 6, 2013 | 10:05 AM
intermitten starting
Old Jul 14, 2013 | 12:16 PM
Starter won't start ?
I've had this problem for a while now. my truck is a 1986 4 cyl. 4 runner.The starter (relay??) just clicks, but my battery voltage is fine. It is intermittent, and eventually it always ends up starting when it feels like it?? I've replaced the starter/battery twice and determined that's not the cause. Could this be the RELAY or IGNITER? I hope someone has the cure because I cannot think what the issue is? I'm afraid to drive it anywhere!!
Last edited by dropzone; Jul 15, 2013 at 06:59 AM. Reason: can't see black on black font
Old Jul 14, 2013 | 12:30 PM
rworegon's Avatar
Dell, can't read your post. Are you using black text? If so, it does not show up so well on a black background.
Old Jul 16, 2013 | 06:50 AM
85sr5excab's Avatar
Make sure ur battery clamps are clean and in good shape, if not replace them. If that doesn't solve it the replace the cables, it's possible they could be damaged somewhere or corroded inside the insulation. Also make sure the smaller positive wire that goes from the battery to the fuse block on the passenger inner fender is in good shape and the contacts are good and clean. Worst case scenario it's possible u got multiple bad starters but I doubt that's the case. Good luck.
Old Jul 16, 2013 | 07:11 AM
wyoming9's Avatar
Red face
Have you tried to hot wire your truck??
By that I mean making sure it is in neutral .
jumper from the the Big lug on the starter to the wire that energizes the starter solenoid.
If it cranks every time your problem is in the ignition circuit.
If you still have issues look to your ground cables .If your getting the clicks I lean more towards the ground cables.
If yours have never been upgraded it might be time
Should at least point you in the right direction.
Old Jul 16, 2013 | 07:25 AM
bbrideau's Avatar
you should hear 2 clicks, one behind the glove box and then the relay on the passenger fender well, if the starter is new and all your contacts are clean and all your grounds are in place that starer relay is usually the next culprit, best to get a friend to try and start it for you so you can listen for the click in the starter relay in the engine bay. It is silver and it will say starter relay or ignition relay. If it has no click it means it is defective. There is a great write up on fixing the click only starter problem by Rad4runner, here is a link.
https://www.yotatech.com/forums/f199...l#post51975700
Ichneumon
Sep 27, 2015 04:21 PM
Sandman
Jul 23, 2015 08:15 PM
puddlepirate
Jun 30, 2015 05:08 PM
bobbybouche
Jun 18, 2015 10:22 AM
Old Red 94
Jun 16, 2015 08:32 PM
