22re pistons
Old Jun 27, 2013 | 09:31 AM
RoadRageRock's Avatar
22re pistons
Is there anyway to know what order piston shoud go in or does it matter?
Old Jun 27, 2013 | 02:51 PM
Stetson_md's Avatar
Fsm says it don't matter as long as you put them back in the hole they came out of with the notch facing foward
Old Jun 27, 2013 | 03:07 PM
Inferno451's Avatar
You don't say if you are installing new pistons or reusing old ones. All 4 pistons are exactly the same, so if installing new ones, just make sure the notch faces toward the front of the engine. If reusing old ones, put them in the same bores they came out of. The connecting rod end caps are numbered, make sure to put those in order, with the point facing the front of the engine as well. Also be sure to put the rings in correctly, with the gaps not lined up.
Old Jun 27, 2013 | 09:13 PM
Thanks for the info
Jcrawl94
10
Oct 24, 2015 04:34 PM
Iceman4193
Aug 28, 2015 08:43 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
