22re Engine Problem
Old Nov 22, 2010 | 08:34 AM
92YotaPickup's Avatar
22re Engine Problem
I'm having a problem with my truck after I drive it for a good ways on the highway.
After I drive for awhile and then pull up to a light or stop sign and go to leave the truck hesitates and stumbles and almost stalls out. But if I press on the clutch again its ok but whenever I try to go it stumbles.
I have also noticed that when Im sitting at the light or stop sign at idle the voltage meter is vibrating at about 14-16.
Looked around the site a bit but couldn't find anything so if you know of a thread like mine just post the link please but I would really like to figure out whats going on with my truck.
Old Nov 22, 2010 | 08:38 AM
irab88's Avatar
what is your idle rpm? you might need to increase it a bit
xxxtreme22r's Avatar
is the hesitation only when your on the gas from a stop or when your stopped with the brakes applied?
Old Nov 22, 2010 | 08:42 AM
Idle is set at about 900-1000...
Right now its only when I'm on the gas...
Old Nov 22, 2010 | 08:45 AM
if it happens only when your on the gas then it's not the fuel cut from the brakes. Which will happen when your idle is too high.
900-1000 although seems kinda high for a stocker. Has it always been like that or has it been like that since you have been having issues?
Old Nov 22, 2010 | 08:46 AM
irab88's Avatar
disregard my previous suggestion. it's something else.
try just looking at your engine for a while. when i do that, i usually find some little thing that's out of place (recently found a coolant leak doing this)
Old Nov 22, 2010 | 08:48 AM
I would start at your fuel filter, spark plugs, wires, distributor cap, rotor and timing when were they last checked/changed/adjusted?
were you doing any maintenance before this started? ie air filter change, oil change etc etc? You could have bumped something loose in the process. Any check engine lights?
Old Nov 22, 2010 | 08:53 AM
Its always been set at that idle... Well since I've had the truck...
The fuel filter, spark plugs, wires, distributor cap, rotor were changed in the summer, timing was checked then too but I think i'll check it again.
No engine light...
Also going to see if theres any codes later...
Old Nov 23, 2010 | 06:16 AM
So I checked for codes last night and got a 42 which if I remember right is the speed sensor which I know is not working.
But I also noticed that the ground wire from the battery to the truck is also broken off on one side.
This morning the truck started doing the hesitation without me going on the highway which is new. It only started after it got warmed up.
It was the same type of thing when I stop at a light and started to go it stumbles and almost dies.
Aswell new today when I got to work I left the truck running for a bit and after 1 or 2 it stumbled it self to a stall. But I could start it right back up after it stalled it self out.
Would really like to figure out whats going on, and hoping I can get home from work today without it stalling.
Old Nov 23, 2010 | 07:17 AM
andykrow's Avatar
yet another bad ground situation... that post-to-body ground needs to be there and be in good shape. go buy a burly cable from napa and see what happens. at least that might have something to do with your fluctuating voltage.
Old Nov 23, 2010 | 07:21 AM
Sounds good, someone sent me a link to another thread thats pretty close to the same thing I'm getting.
Thanks for the help, I'll let you guys now what happens
Old Nov 23, 2010 | 12:20 PM
So I changed my ground wire from the battery to the fender but didnt help.
So any other ideas.
Old Nov 23, 2010 | 08:52 PM
irab88's Avatar
what about grounding the block? (wire from block to body)
Old Nov 24, 2010 | 07:34 AM
Were is that wire located?
Old Nov 24, 2010 | 08:02 AM
irab88's Avatar
i don't think there is one, but adding one might help (i think)
Old Nov 24, 2010 | 08:11 AM
richf's Avatar
I just finished up with ground issues on my 22re. You should have a ground that goes from the battery to the motor mount, ground from the motor mount to the passenger fender well, positive to the fuse, positive to the starter and charge wire from alternator to same fuse as the positive from the battery. Check them all out. I used all new 4 gauge wire from my local welding shop.
Philbert's Avatar
I believe that there are some unused holes on the bottom of the block, where the oil pan mounts - same size bolt as the oil pan bolts. You could use those to attach a ground wire?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
