Proper way to perform radiator flush
Old Nov 18, 2010 | 10:43 AM
Chris Shades's Avatar
I just picked up a 94 extra cab 2 wheel drive with 129k miles. Runs super but I poped the cap on the rad and its full of brown fluid so im guessing it needs a flush. Whats the proper way to go about doing the flush and is there a plug on a the block or should I just disconect the lower hose to drain the fluid?
Old Nov 18, 2010 | 10:54 AM
waskillywabbit's Avatar
Drain radiator. Dispose of fluid properly.
Fill with water. Remove upper hose to radiator from radiator side only and aim down. Turn on heater. Crank truck. Take off radiator cap and stick running hose in it. Run until tstat opens and water comes out clear from upper radiator hose. Stop everything. Drain radiator. Refill with antifreeze.
:wabbit2:
Old Nov 18, 2010 | 10:58 AM
Thanks!
Old Nov 18, 2010 | 10:59 AM
camo31_10.50's Avatar
i don't think you'd be able to do it like that with the 3vz though...could you?
i need to flush mine, dang rusty radiator
Old Nov 18, 2010 | 11:13 AM
Mines is a 22r-e so Im gonna give it a shot.
Old Nov 18, 2010 | 12:21 PM
tumor21's Avatar
When I had my '91 Runner I did the same steps on it's 3.0. seemed to work fine.
Old Nov 18, 2010 | 01:59 PM
hross14's Avatar
what about some vinegar to break up the scale?
Old Nov 18, 2010 | 04:43 PM
RustBucket's Avatar
You can also open the drain on the driver's side of the engine block and let water flush through that if you want to just do the whole cooling system.
Blamalam
Mar 12, 2022 07:34 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
TJWilly
Jul 31, 2015 02:05 PM
Logz808
Jul 26, 2015 07:09 AM
jjrbus
Jul 19, 2015 02:06 PM
