Shifter info
Old Nov 19, 2010 | 09:43 AM
Toyota dad's Avatar
Shifter info
Will the same shifter work for a 4 cly Tranny (W56) to a V-6 5-Speed?
Thanks for any help
Old Nov 19, 2010 | 09:57 AM
250000_yota's Avatar
I believe they are different. I'm basing this off the fact that if you look at websites like LC Engineering and URD, who sell short throw shifters, they sell different shifters for the V6 trans and the 4 Cylinder trans.
Anyone else could probably give you a slightly better explanation, but I just dont know the major difference.
Old Nov 20, 2010 | 11:05 AM
87 'runner boosted's Avatar
can shifters be rebuilt??? I looked up parts on advance and autozone...didnt seem to find anything. I cant stand having a sloppy gear shift and seems as though there should be a bushing of some sort in there that would cure that problem...any takers?
Old Nov 20, 2010 | 11:19 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
No.
If you've got a sloppy shifter, try a bushing...
http://www.marlincrawler.com/transmi...t-lever-socket
Old Nov 20, 2010 | 11:20 AM
where you find those bushings at? I havent been able to locate one anywhere...
Old Nov 20, 2010 | 01:14 PM
MudHippy's Avatar
MarlinCrawler.com is the ONLY place you will find them.
And it's actually the shifter seat that causes the most noticeable looseness in the shifter. The part shown above is the socket, and is the least likey to cause looseness or need replaced. But if you're going to replace one, you should replace the other at the same time just in case.
It's also a good idea to replace the boot on the shifter lever if it's cracked. The small rubber boot that you have to move out of the way to remove the shifter and replace those parts is what I'm talking about. It's called the shift handle boot, and Marlin also sells them. Not the 2 upper boots that are bolted to the floor of the cab.
TheBFA
Feb 15, 2020 06:55 AM
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
buckz6319
Aug 5, 2017 03:50 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
White Stripe
Oct 6, 2015 10:47 AM
