Driving RPMs Too High ?
Old Nov 17, 2010 | 04:57 PM
McKenna's Avatar
Driving RPMs Too High/Code 64 ?
Vehicle: 92' 4Runner, 3.0 4x4 A340H, 202Kmi rolling on 31x10.50R15 A/Ts, stock gearing. Headgasket, waterpump, Thermostat, Timing Belt done @ 182K. I purchased the rig back in late July from a local Mechanic/Shop owner, This is my first 4runner as I upgraded from a Jeep XJ.
My Issues:
At 65MPH with O/D on the truck is running right at or a hair under 3K RPMS
At 65MPH without O/D on the truck is running right at or a hair under 4K RPMS
Recently my OD light began to flash a Code 64, I took it to a family friend whom was in the Transmission Business for 30 years. We both took the rig for a drive test around town & on freeway, the A340 shifts Fine and hits all its shift points & has never had any issues shifting into OD. Stall speed is around 2700RPMS which is normal from what I've been told.
My Question: Is 3K RPMs @ 65 with OD on normal for 4runners ? (I'm used to my Exploders & XJs to be from 1800-2300 @ 65.) What would bring these RPMs up & why would I be getting a Code 64 is nothing is mechanically or electrically wrong w/ my Trans ?
Old Nov 17, 2010 | 05:02 PM
Marc's Avatar
Rev's are normal.
You'll have to check the FSM to see what a code 64 means.
Old Nov 17, 2010 | 05:18 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Run your RE or VZ at those RPMs and see what it does if it'll make you feel better...
Ford, Dodge, Chevrolet,,, Toyota's are not.
Old Nov 17, 2010 | 06:35 PM
McKenna's Avatar
I told the mechanic 3grand is just getting into powerband but took his advice & figured I'd ask here to be on the safe side. Now I just have to figure out WTF is up w/ that Code 64 if nothing is actually wrong.
Old Nov 17, 2010 | 07:27 PM
just call me smithy's Avatar
he is correct about the power band, 150 hp at 4800 rpm with 180 ft·lbf of torque at 3400 rpm, these motors like rpms.
Old Nov 18, 2010 | 04:56 PM
jbw's Avatar
jbw
I also recently "upgraded" from a 1998 XJ which I totalled and am driving a 2nd gen 4runner with the 3VZE now..
Within a week of owning the 4runner I was trying to figure out how the hell I could swap in a H.O. AMC straight six/AW4/NP242 combo. Now I've just gotten used to the high RPM's, getting passed by grandmothers on their way to church, the terrible gas mileage (even compared to a Jeep!) and the tinfoil body panels. It's a toyota thing, I understand
Truth be told, the Toyota does feel like a solid vehicle but I think it'll take some time to get used to the power difference between the AMC straight six and the 3VZE
Last edited by jbw; Nov 18, 2010 at 04:59 PM. Reason: edited to gripe about the horrible gas mileage too!
Old Nov 18, 2010 | 05:20 PM
SpecialScottie's Avatar
I run my 22re at 3500 all day long on the highway. I think it likes it
Old Nov 21, 2010 | 04:22 PM
bmcghie's Avatar
My 3VZE seems to purr at 4k on the highway. My speedo is busted, so I think I'm hitting around 120-130km/h. It's done many 8hr stretches at those revs, up and down some hilly highways, with no problems. Transmission gets a little warm through the floorboards (5spd), and the engine burns a bit of oil... but I love it.
Old Jan 30, 2011 | 09:07 PM
multipse's Avatar
i am also new here, i have a 94 3.0 vze engine i think, with 31"s and im going 65mph but my rpms going at about 3200 is that normal? it has a 5sp manual tranny 4x4. Im concerned please help
Old Feb 2, 2011 | 12:55 PM
94 SR5 Mountaineer's Avatar
^^ that sounds normal to me. My 3vze runs about 3000 at 70 mph, which is probably lower than average because of my bigger tires with stock gearing.
Old Feb 2, 2011 | 10:01 PM
multipse's Avatar
Thanks for the reply, I'm concerned of high rpms because i know my engine need some work, it suffers form that famous lifter noise these engines make.SHould i try and keep her under 65 mph because of the lifter noise?
also what tire size u put in your 4runner? and did it need to be lifted for them to fit?
I love the 4runner just think i should have gotten one with a 3.4
Old Feb 2, 2011 | 10:05 PM
multipse's Avatar
thnx for the reply, i guess im a bit too new to this engine.
Old Dec 10, 2011 | 11:17 AM
90_4x4's Avatar
I'm new with the 3vze also and my runner with 4.556 gears auto tranny and 32's gets 12mpg.... At freeway speeds at 3k rpm in OD
Old Dec 10, 2011 | 02:04 PM
neb21's Avatar
I have a 22re with 4.88's and 31 inch tires and I run 3K to 3.5K on the highway. Since re-gearing and adding the tires plus adding a V-6 Sr5 cluster I do not know my exact speed. Doesn't seem to be winding out at all though.
smthwsn357
May 1, 2024 07:28 AM
ZONAYODA
Jul 13, 2015 07:17 PM
cars-guy
Jul 11, 2015 07:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
