Water pump question
Old Nov 26, 2010 | 09:25 AM
SDHNTR's Avatar
Water pump question
My water pump is leaking just a bit of coolant from the weep hole. The motor (22re) has 238K miles on it and it is a Toyota water pump so my guess is that it's original. Is leaking out the weep hole indicative of anything? Does it mean any inner seals are worn and the pump is heading south?
Old Nov 26, 2010 | 09:33 AM
4Crawler's Avatar
Yep, that is it. Seal leaks, then that coolant gets into the bushings, causing them to wear out and then the pump seizes up and fails. That is why the weep hole is there, to warn you of the impending problem.
Old Nov 26, 2010 | 09:40 AM
SDHNTR's Avatar
Oh great! Not fun.
I'm going on vacation in a week and really don't have the time to tackle this. Any rough idea what a shop might charge?
Old Nov 26, 2010 | 10:36 AM
snobdds's Avatar
Honestly by the time you take it into a shop and leave it there for a day and then pick it up...you could have it changed out. It only takes maybe 2 hours. It just involves taking off the intake tube, shroud, fan and belt and your there.
One suggestion would be to get a new one from the dealer, they are better than any thing you can get at the part store. Also, put some new belts on there...from the dealer too.
Old Nov 26, 2010 | 10:48 AM
mightymouse's Avatar
x2 easy job just do it yourself. If you do take it to a shop it should only cost under 200 or so. I think last time i had a shop do a water pump on a 22re it cost 167 and some change with oe parts.
Old Nov 26, 2010 | 01:40 PM
sb5walker's Avatar
Just FYI the silicates in Prestone Green are slightly abrasive and will wear pump seals faster than Toyota Red. That's one reason why Japanese auto makers don't recommend silicate coolants. But given enough miles, the seals will fail even with Toyota Red. snobdds' recommendation to get a dealer pump is good; the OEM is Aisin and they will outlast any other pump. autohausaz.com sells Aisin parts for cheap and give free ground ship on orders over $50 (no affiliation - but have had good luck with them).
Good luck with it.
Old Nov 26, 2010 | 04:36 PM
Buck87's Avatar
Be careful removing the bolts sometimes they get stuck and break, which makes an easy job into a PITA. Do not force them use penetrating oil/heat/tap with a hammer instead of brute force. Check out this thread first if you are planning on doing it your self. https://www.yotatech.com/forums/f116...broken-138709/
Old Nov 26, 2010 | 04:48 PM
muddpigg's Avatar
Good luck with it.
Thanks for the part supplier info.
What he said and use antisieze when reinstalling.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Snort
Jul 19, 2015 07:03 AM
TammyMarie
Jul 15, 2015 11:14 AM
Jonny246
Jul 12, 2015 04:51 AM
