Long water pump bolt in 22re broken???
Old Feb 28, 2008 | 05:14 PM
CW's Avatar
CW
Question Long water pump bolt in 22re broken???
I just pulled a head off a smashed truck that just had a new head and timing chain done and when i pulled it all apart the long bolt that goes through the pump & timing cover into the block broke off in the block. I need to do a timing chain on mine and wondering what to do if it breaks on mine?
Cant even see the bolt in the block.
How common is it for these to break? Does that bolt need to be there?
Old Feb 28, 2008 | 05:23 PM
Targetnut's Avatar
I've not seen anything like that on a 22R yet, but I have seen it on other makes before.
If you find it stuck, don't go whole hog on it. first try tapping the bolt sharply with a hammer like you are driving a nailjust work on it, if you get it to move a half turn or so and it is still tight, spray some penetrating oile such as PB Blaster, WD40, CRC 5-56, or something similar and leave it soak then tap it more with the hammer and soak it somemore then work it slowly.
Unfortunately, sometimes it is inevitable that it is going to break and you will just have to drill it out.
Old Feb 28, 2008 | 05:24 PM
muddpigg's Avatar
Use antisieze when you assemble, I boke one off had a hell of a time. If it freezes try penetrating oil and heat, not brute force. Good luck.
Old Feb 28, 2008 | 05:41 PM
CW's Avatar
CW
Hopefully i dont have this issue with mine but the way things go for me lately im kinda expecting it.
Old Nov 14, 2010 | 12:28 PM
Buck87's Avatar
I just broke the same bolt in the 22re engine that I am using as a core (long water pump bolt). Does anyone know the length of bolt that I should buy as a replacement?
Old Nov 15, 2010 | 07:46 AM
Buck87's Avatar
For the record my bolt was 3 1/4" long 8X1.25.
Old Nov 23, 2010 | 02:59 PM
Buck87's Avatar
Yes, the bolt is the same diameter and pitch as the others but for some reason the head size is different.
icentropy
Sep 16, 2020 02:47 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
