? rust HOLES repair, cab
Old Nov 30, 2010 | 11:48 PM
duck tape's Avatar
wanting to get ideas on how to repair this rust bucket
missing cab corners and rockers, and much more
the cab mount by the right door is useless. the door is sagging down, and must be pushed up, and the rear pillar pushed in to close the door
the floor insulation came off easily in large chunks with a hammer and chisel.
I do have a welder and a donor xtracab
Old Dec 1, 2010 | 01:17 AM
myyota's Avatar
I think you would be better off doing a cab swap instead of trying to repair that rust, if it was just a few small rust holes then it would be worth it, but that cab has major structural damage and isn`t worth trying to fix.
Old Dec 1, 2010 | 01:37 AM
TinMan's Avatar
I have a good cab with one rust hole that you can have. But you need to pay for freight to ship it. I need to get it out of the yard. The cab is stripped to the shell only. Just let me know. I am on the coast in NC.
Later
Old Dec 1, 2010 | 03:33 AM
andrewflores17's Avatar
alot of JB weld putty
Old Dec 1, 2010 | 08:43 AM
Shifty762's Avatar
Duck Tape?
Old Dec 1, 2010 | 10:20 AM
myyota's Avatar
Gallons of JB Weld and a train load of duct tape might fix it .
Old Dec 1, 2010 | 12:17 PM
duck tape's Avatar
anybody need parts off it?
I'm going to scrap it out
not worth fixing
will use parts from it to repair the xtracab
only making a temporary patch to keep some snow out this winter while it sits till spring
Old Dec 1, 2010 | 12:57 PM
wyoming9's Avatar
Red face
I really didn`t think it was all that bad about average for the ones I fix.
What the heck it is your truck what ever works for you.
Old Dec 4, 2010 | 07:30 AM
toyota884runner's Avatar
i had this problem on my 4runner and ground away the rust and wire wheeled it and then use the foam to feel gaps and pop riveted some sheet metal in place and used the foam to fill the gaps and used rubber undercoating on the back side. i did that a year or 2 ago. seems to be holding up alright.
young buck
18
Aug 27, 2018 02:40 PM
mdev126
Oct 4, 2015 04:48 AM
Robojd1
23
Jul 21, 2015 01:43 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
hexrain
Jul 12, 2015 01:13 PM
