88 4runner AC recharge
Old Nov 20, 2010 | 03:37 PM
SDHNTR's Avatar
I'd like to recharge my AC system. Is there a tutorial somewhere on here to use as a demonstration? Can I use the newer style refridgerant?
Old Nov 20, 2010 | 08:07 PM
yeehaw1's Avatar
I don't know about a tutorial, but it isn't that hard as long as you still have a vacum on your system, and you can only use R-134a refrigerent if your truck has been converted to accept it. (well you could probably use it anyway, but it would more than likely tear something up)
Old Nov 20, 2010 | 08:25 PM
SDHNTR's Avatar
I have no idea if it has been converted and I don't want to tear anything up. How can I tell?
Old Nov 21, 2010 | 05:48 AM
SDHNTR's Avatar
OK so I need to look for a can that says it is compatible? Will it say so on the can itself? Where do I hook it up and what PSI to I run it to?
Old Nov 21, 2010 | 08:10 PM
SDHNTR's Avatar
Did a little more research. Found that only 134a nozzles will fit on 134a valves, and 134a is all that is really available at auto parts stores these days. So if my truck has a 134a valve installed, it has already been converted and I should be good to go to right? Would it be safe to assume that if it has this valve, the R12 has already been removed and I can now recharge safely with 134a?
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
nanhodges2733
May 29, 2020 03:28 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
