Bracket lift info
Old Nov 20, 2010 | 12:06 PM
PR_TRUCK's Avatar
Bracket lift info
Hello guys, i have search here and in the web and all i get is information on kits. My question is how the bracket lift works and a picture. In all the pictures what i see is a kit and dont know exactly what is the bracket. I want to lift the front to match the 1 leaf int he back. Thanks!!
Old Nov 20, 2010 | 12:15 PM
peow130's Avatar
Well the bracket part is a part that looks like your differential crossmember. It bolts in and effectively lifts your truck by lowering the lower control arms away from the body.
then the knuckles come in. They match the length of the lift.
in all honestly, bracket lifts dont get you any ground clearance, except breakover and rear axle.
However, the larger tires that you fit on the truck will give you maybe 2 to 3 inches of clearance
Old Nov 20, 2010 | 12:29 PM
JamesD's Avatar
Brackets are just spacers to move the components down in which in return gives you more room in the wheel well for bigger tires. That is just a generic description. This is for the front suspension.
James
Old Nov 20, 2010 | 03:25 PM
PR_TRUCK's Avatar
know a page where i can buy alone? All the pages i have see sell the complete kit. Is a 88 pickup 22re. Any more suggestions on the front lift? Right now i have a bj spacer and want to relax the sway bars.
Old Nov 20, 2010 | 03:44 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Bracket lifts are 4".
What does this mean?
Old Nov 20, 2010 | 03:48 PM
Everything is a bracket/ spacer. There are spacers that allow you to mount the diff in its new position, from the old one...
And there are spacers that drop the new lower control location down 4", and spacers that allow the upper ball joint to used in its stock location. Only, the hubs were moved down along with the lower control arms and front diff...
Bracket, spacers... It's all the same thing.
Old Nov 20, 2010 | 04:47 PM
PR_TRUCK's Avatar
mmm ok, sorry i am a noob in this. Can post a link to the spacer for the lower control arm? Thanks for the replies guys!!
Old Nov 20, 2010 | 06:05 PM
30 seconds on google...
http://4x4mecca.com/tech_article/198...ck-or-4-runner
EDIT: Holy crap that link needs to be stickied....
EDIT: EDT: Holy crap that link needs to be stickied... It has individual part numbers! For individual parts!
shisha1999
Aug 14, 2015 01:33 AM
coffey50
Jul 28, 2015 10:55 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
Fundy Rider
Jul 16, 2015 01:35 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
